Power from 3v6 Lithium batteries
I run a Propeller from 3V6 lithium batteries for some time now without problems. The cheap type I use is AA sized and contains around 1 Ah.
Open circuit voltage is 3V7, when drawing 50 mA it drops down to 3V4.
I should consider this safe conditions (I know the datasheet says: 3V6!). Other experience?
Doug
www.lithium-batterie.de/html/allgem2.htm
SL 760 is rated for 60 mA max - and it's even 2 Ah capacity
I made some research in the meantime. It seems I got them VERY cheap ($2) from overstock. I see offers upto $10 for one now.... I was not aware of that...
Edit: A major producer is here: www.tadiranbat.com/iXtrac.php
They give the "normal discharge" as just a few mA, but my experience is that you can safely draw the maximum value (20x) which is not always stated... However this is what I am unsure about...
Edit2: Quite a science... www.tadiranbat.com/lithiumsnotalike.php Seems I am just lucky with my batteries
Post Edited (deSilva) : 10/30/2007 1:01:42 AM GMT
I want to (preferably) run my system from a single 3.7v LiPoly battery.
I haven't worked out my current draw yet but the system includes a GPS, Accelerometer, Gyro, Digital Compass, 2 x Digital pressure Sensor, RTC, ADC and DataFlash.
The best i've found so far has been the 3.7v Varta AA-Size cylindrical 2600mA.
Does anyone know of any better, or have any other recommendations?
Kevin
When talking of rechargeables, there are many possibilities, starting from 3 times any 1.2V cells be it NiCd or NiMH. Their price/performance ratio is unbeatable, and there is an immense variety.
Main issue might be that fully charged 1.2V cells in fact have 1.35V which adds up to 4 Volts , NOT going down at medium load, as they are high current devices (upto 10A and more).
When it comes to size and/or weight Li-Ion or LiPo is of cause the device of choice. I see no advantage of LiPo over Li-Ion for most applications at the moment, this will change when LiPo becomes more mature.
The small Li-Ion devices used for cameras are really sweet. Just opening any catalogue I found 640 different kinds
European prices go from 5 Euros to 15 Euros. As Kevin101 said, chargers for them are reasonably priced...
