Simple Circuit - LED on RES line?
Is there a way to have a status LED on the RES line of a BS2? I know that RES is tied high internally and you pull it to ground to reset, but what is a good way to show the status of a currently running stamp?
I've found that a momentary RESET still leaves 5v on VDD so you can't use that, VIN is no good as that relies on turning the power OFF at the source?
Please help me with a simple status LED?
Many Thanks in advance,
Morrolan
Flying is simple. You just throw yourself at the ground and miss.
"I think computer viruses should count as life. I think it says something about human nature that the only form of life we have created so far is purely destructive. We've created life in our own image."
Stephen Hawking
Morrolan
Stephen Hawking
Another approach is to use a piezospeaker that emits a tone for a few seconds at the begining of the program... same concept... Once your program is running, if you hear the tone again, you know that your program has just started over, which is indicative of a reset occuring.
Stephen Hawking
Stephen Hawking
