OEM BS2: Wrong Impression of VDD and VSS?
All--
On my BOE, I get regulated 5vdc between VSS and VDD.
Using my OEM BS2 in a breadboard, I get the battery voltage between VSS and VDD (and between VSS and any output pin set high).
Can you please clear up my misunderstanding? Is there a way to get regulated 5vdc off an OEM Stamp?
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
I had it right when I proto-typed it. But, somewhere between doing that and building it I forgot and screwed up. When I made the changes you provided, everything was good again!
Thank you.
--Bill
