TeleText
hippy
Anyone done anything towards getting PAL TeleText generation working ?
I've tried Phil Pilgrim's closed-captioning object but didn't get far. Either my TV doesn't support closed captions or it's the NTSC. With the low-level driver changed to generate PAL the TV decoder flashes up a "***TXT***" which I recall means it sees a signal and is looking for TeleText which doesn't happen with NTSC.
http://forums.parallax.com/showthread.php?p=604019
