PENGUIN ROBOT Body Switch - the Code
The Amazing Penguin Body Switch
penguin_body_switch.bpx
Turns Penguins' body into a virtual on/off switch
Penguin now has a software latching on/off switch
using this code! The program is part of the Virtual
Reality series, adding VR hardware to Penguin
using only software. It's also a compass program
in the code series.
Turn Penguins body to switch on or off! Now you
can control sections of code, turning things on or
off, using this technique!
humanoido
in the code series.
humanoido
' This is a virtual on/off switch using Penguins' body and compass. ' To turn on the switch, move Penguins' body until it faces North. ' A high pitch tone is heard. To turn off the switch, move Penguin ' to South. A low pitch tone is heard. The switch is latching. Once ' it's on, it stays on until switched off. The switch condition is ' reported to the Debug screen. ' The tone will sound when the body is within the specified range. ' When the target body switch position is precisely reached, the tone ' will become steady. To squelch the tone, the body is offset. ' This program requires compass calibration. ' 90 - East ' 180 - South ' 270 - West ' 360 - North ' If the compass angle is from 0 to 5 ' or 355 TO 360 then switch on (North). ' If the compass angle is from 175 to 180 ' or 180 to 185 then switch off (South) ' Expand the code to create a VR multifunction switch, and turn ' multiple elements on and off!
