waitpeq/waitpne help please — Parallax Forums
LafetLafet Posts: 23
edited 2007-10-27 13:42 in Propeller 1
Hi, can you help me please?
CON
        _clkmode        = xtal1 + pll16x
        _xinfreq        = 5_000_000
        in_pin = 6
VAR
  long Index
PUB start
Index := 0
dira[noparse][[/noparse]20]~~
outa[noparse][[/noparse]20]~
coginit(6,@entry, @index)
repeat
DAT
       ORG   0
entry
:det_pulse
        mov             _count, #6
        mov             _tmp_count, _count
        jmp             #:det_pulse_loop
:det_pulse_cnt
        cmp             _tmp_count, #6  wz
 if_z    mov             _count, #7
 if_nz  mov             _count, #6
:det_pulse_loop
        waitpeq         _null, #in_pin
        waitpne         _null, #in_pin
        djnz            _count, #:det_pulse_loop
        rdbyte          _temp, par
        add             _temp, #1
        cmpsub       _temp, #6
        wrbyte         _temp, par
        jmp             #:det_pulse_cnt
_null   long  0
_temp   res   1
_count  res   1
_tmp_count    res       1
Why waitpeq don't work?
Function: waiting 0 -> 1 -> 0 on P6.
Very thanks, Lafet
  • deSilvadeSilva Posts: 2,967
    edited 2007-10-24 21:30
    WAITPEQ and WAITPNE take a complete 32 bitpattern as parameter not the portnumber. You have also to state the MASK correctly, also 32 bits long.
    When using I/O #6 you can still use immediate addressing #%100_0000 or - better! - # |<in_pin
  • LafetLafet Posts: 23
    edited 2007-10-24 21:42
    waitpeq         _null, #|<in_pin
    waitpne         _null, #|<in_pin
    waitpeq         _null, #%100_0000
    waitpne         _null, #%100_0000
    waitpeq         %100_0000, #%100_0000
    waitpne         %100_0000, #%100_0000
    Post Edited (Lafet) : 10/24/2007 10:10:50 PM GMT
    edited 2007-10-24 21:53
    I said:
    deSilva said...
  • hippyhippy Posts: 1,981
    edited 2007-10-24 22:45
    Lafet said...
    ...don't work
    You need a register in the destination field ...
    mov             reg, #%100_0000
    waitpeq         reg,reg
    waitpne         reg,reg
    edited 2007-10-24 23:07
    @Lafet: Just to explain it:
    Alas, it is possible to write things like:
    waitpne         %100_0000, ....
    although it will make little sense to the human reader, except he is very unexperienced with the SPIN assembly language wink.gif
    For the assembler this is the clear instruction to use the mask stored at address number 64 of the COG - why not?
    A VERY GOOD assembler would issue a
    "WARNING: Unrecommended and most likely erronious use of bit-literal as register number!" smile.gif
    What do we learn from this? Don't use I/O pins below number 9 smilewinkgrin.gif
    Post Edited (deSilva) : 10/24/2007 11:22:11 PM GMT
    edited 2007-10-24 23:21
    All of the above is good info. I would add that the setup of the I/O (dira, outa, ina) be moved in to the assembly program. I won't recount each time I messed this up, it is more times than I care to share. The I/O for each cog needs to be setup. In the example above the cog running the spin portion of the program has its I/O setup, but then the assembly program is launched into another COG with its own I/O registers. By default the registers are all inputs, so sometimes not setting up the I/O won't show as a problem if you are using only inputs.
    Timothy D. Swieter
    tdswieter.com
    One little spark of imagination is all it takes for an idea to explode
    edited 2007-10-24 23:28
    Thank you, Timothy.
    This is the real reason why it won't even work with the latest try - and hippy and me would have been very, very surprised smile.gif
    edited 2007-10-25 01:34
    Thanks deSilva. There have been many times when you posted a response and duh it was so obvious how did I/the poster/the forum miss the problem. Glad I could beat you to it this time. Your help on the forums is appreciated.
    Timothy D. Swieter
    tdswieter.com
    edited 2007-10-25 09:07
    entry
            mov             det_pin, #1
            shl             det_pin, #6
            andn            dira, det_pin
    :det_pulse
    :det_pulse_loop
            waitpeq         det_pin, det_pin
            waitpne         det_pin, det_pin
    det_pin   long 0
    _tmp_count    res  1
    edited 2007-10-25 12:59
    Wrong pin used ?
    Hardware connected to wrong pin ?
    Signal not toggling ?
    Signal toggling too fast ?
    Incorrect signal voltages ?
    _count not initialised correctly ?
    That code not being executed ?
    Other code error ?
    Error in your data definitions ( res before long or before code ) ?
  • ErNaErNa Posts: 1,862
    edited 2007-10-25 14:47
    In this case, You should post the complete program (if not too big). If too big: remove everything not necessary to produce this error.
    edited 2007-10-25 19:11
    Full programme is at first benefit. After it only his adjustment. I replaced program part with waitpeq/waitpne following:
    one
            mov             _temp, ina
            and             _temp, det_pin  wz
    if_z    jmp             #one
    null
            mov             _temp, ina
    if_nz   jmp             #null
    and this way it works OK.
    edited 2007-10-26 07:11
    Good to hear!
    (a) You are now waiting the other way round 0->1 rather than 1-> 0 in your first postings
    (b) You do not need the _temp
    one
            and              det_pin,   INA  wz,NR
    if_z    jmp             #one
    null
    if_nz   jmp             #null
  • mparkmpark Posts: 1,336
    edited 2007-10-26 18:02
    (a) I don't think that's quite correct. 0->1 just gets past the first loop; the signal has to go 1->0 to leave the second loop, no?
    (b) But why didn't this work?
    edited 2007-10-26 19:42
    mpark said...
    Just because it's different..
    edited 2007-10-27 01:12
    Works ...
    one
            mov             _temp, ina
    if_z    jmp             #one
    null
            mov             _temp, ina
    if_nz   jmp             #null
    Apparently doesn't work ...
    I have to admit that I cannot see the difference.
    In the first case the 'one' loop is only left when ( INA & det_pin ) <> 0 and the 'null' loop is only left when ( INA & det_pin ) == 0. So it waits firstly for pin high then pin low.
    I do not see any difference to how the waitpeq/waitpne proceeds - waits for pin high then waits for pin low, so I'm at a loss to explain why the first works but the second does not.
    edited 2007-10-27 02:14
    Hmmm. I cannot see the difference either.
    There must be something else going on that you can't see from these fragments.
    Are you literally substituting one for the other?
    edited 2007-10-27 09:17
    I agree: no difference!
    Both will wait for 1 -> 0
    Sorry for having been slop(p)y!
    Edit:
    But I was a little bit confused as the very first solution was this:
    I have to look it up from time to time, "who is who":
    its:
    WAITP value, mask.
    So this (reported: not working) example looked for 0 -> 1
    Then it became a little bit confused... In fact DIRA wil have nothing to do with it, as input is default and - contrary to my former posting - this had no influence on it.....
    Remains the last riddle: Two obviously equivalent programs behave differently...
    Post Edited (deSilva) : 10/27/2007 1:23:31 PM GMT
    deSilva said...
    I was on my way to posting exactly as you did but caught myself before pressing send; "there but for the grace of God go I" smile.gif
    There has to be something else which is not being revealed. My gut suspicion is that the "waitpeq/waitpne" is not in the same order used in the code test.
