Hydra SD card
Baggers
Hi Andre'
What's the pins for your Hydra's SD card?
Post Edited (Baggers) : 10/24/2007 4:17:26 PM GMT
Andre'
You won't be able to have my hicolour videos playing on hydra as they use the PropGFX add on, which uses the expansion port.
Your card should be able to play the Hydra palette'd video's though, like the oxygene demo.
Baggers.
You'd have to create some type of pass-through for both NES controllers to get the four required data
lines, but Vss and Vdd would already be in place.
Thinking about this a little more, does a COG take exclusive control of an I/O pin to run both at once?
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
It'd be one or the other,· meaning SD or nespad.
Andre'
Which pins does the Hybrid use for the SD card ?
Do you have any software for loading/saving on the card...
I got an SD holder and I'm going to try and solder it down on the Experimenter card...
I really don't know much about the SD card or how to hook it up so I'm going to do some research later tonight...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
The Hybrid uses pins 8,9,10,11, but the Hydra isn't pin compatible with Hybrid.
Although you'd probably be better to wait and see what pins Andre's using, so you'll have pin compatibility with his stuff too [noparse];)[/noparse]
Jim.
PS, there's Oldbitcollector's Cookbook for great info on SD cards.
http://forums.parallax.com/showthread.php?p=665736
Unterwelt (My first game for the HYDRA):
http://forums.parallax.com/showthread.php?p=696204
Hydra in a LEGO NES:
http://forums.parallax.com/showthread.php?p=654788
I'm not too worried about being pin compatible with the Hydra SD card reader, that can be changed later...
Just want to test it out and see if I can get it to work, if not I'll get Hydra SD card reader...
Experience level:
/Bamse
I'll leave some extra slack on my wires so they can be re-routed if necessary...
Experience level:
/Bamse
In the case of the Hydra, you'll have to use a memory expansion or I/O expansion card and wire up a cable (I used the two ends of a 3-pin servo cable and cut it in half) with +3.3V-33VCC, Gnd-Gnd, DO-I/O_0, Clk-I/O_1, DI-I/O_2, CS-I/O_3.
On the SD card, there are two ground pins, 3 and 6, I'm assuming that I'll connect both to GND...
Experience level:
/Bamse
It's pretty cool that you can save and load files...
See if I can find a boot loader in the Propeller forum...
I saved some slack on the wires so it looks pretty "home made" with wires sticking out on the side...
Experience level:
/Bamse
The boot routine takes a starting sector number on the SD card and a file length (in bytes). The boot routine can't handle multiple file extents, so you'll need to format the SD card with 32K clusters.
http://forums.parallax.com/forums/default.aspx?f=33&m=230231
The boot menu is working great and it is the sdspiFemto.spin driver...
Loading up with 3DMM, Frogger, Jetpack, Mercury mission, Dodgy Kong, Planetary defense etc...
Got some more testing to do, but so far so good...
Experience level:
/Bamse
