Drawing Vectors — Parallax Forums
Drawing Vectors
zoomszooms Posts: 4
edited 2007-10-29 17:14 in Propeller 1
I am using the propeller in a class project and I am trying to draw a vector based on a starting point, angle, and magnitude. I am going to use this to make a wheel spin using the tv and the graphics objects.
  • BaggersBaggers Posts: 3,019
    edited 2007-10-24 15:47
    Very good [noparse]:)[/noparse]
    Good luck in your class project.
    Baggers.
    PS, don't forget to post pics of the finished project.
  • zoomszooms Posts: 4
    edited 2007-10-24 16:27
    has anybody done anything like this before?
  • deSilvadeSilva Posts: 2,967
    edited 2007-10-24 16:28
    Yes!
    edited 2007-10-24 16:35
    You could succeed with steps == 1 or steps == 2 ; and check the arcmode you will need!
    PUB arc(x, y, xr, yr, angle, anglestep, steps, arcmode)
    '' Draw an arc
    ''   x,y            - center of arc
    ''   xr,yr          - radii of arc
    ''   angle          - initial angle in bits[noparse][[/noparse]12..0] (0..$1FFF = 0°..359.956°)
    ''   anglestep      - angle step in bits[noparse][[/noparse]12..0]
    ''   steps          - number of steps (0 just leaves (x,y) at initial arc position)
    ''   arcmode        - 0: plot point(s)
    ''                    1: line to point(s)
    ''                    2: line between points
    ''                    3: line from point(s) to center
  • PerryPerry Posts: 253
    edited 2007-10-25 16:21
    The Graphics demo that comes with the Propeller IDE has several good examples of rotating objects
    Perry
    edited 2007-10-25 18:13
    Yes run the graphics demo and also look at graphics.spin you can draw circles as deSilva suggests and you can draw lines with plot and line functions there is also a function called vec which will draw a vector sprite (some image made from vectors defined in the dat section) at whatever scale, position and rotation you require.
    I used the vec function to create some clock type graphical elements see:
    http://forums.parallax.com/showthread.php?p=682917
    For a wheel you could make a vector sprite like a star for the spokes and use arc for the rim, then move the rim and move and rotate the spokes for the rotation effect as it rolls. Using PI in there somewhere will make it look more realistic.
    Graham
    edited 2007-10-25 18:34
    Thank you all for your suggestions. I have used the graphics demo and the plot/line, arc, and·vec commands in the graphics object. I have also tried modifying the graphics demo. My problem is that I haven’t been able to figure out exactly how to draw what I need to draw with the vector and vector arc commands. I can't really figure out what the different numbers do within the sprite definition. Another problem with modifying the graphics demo is that all of the objects (the little dogs and stars) rotate around a center point, while remaining upright. I need one object to rotate around its center. Could anyone post a better description, or a different method, of how to draw the sprites?
    edited 2007-10-25 18:57
    from graphics.spin:
    PUB  vec(x, y, vecscale, vecangle, vecdef_ptr)
     Draw a vector sprite
       x,y            - center of vector sprite
       vecscale       - scale of vector sprite ($100 = 1x)
       vecangle       - rotation angle of vector sprite in bits[noparse][[/noparse]12..0]
       vecdef_ptr     - address of vector sprite definition
     Vector sprite definition:
        word    $8000|$4000+angle       'vector mode + 13-bit angle (mode: $4000=plot, $8000=line)
        word    length                  'vector length
        ...                             'more vectors
        word    0                       'end of definition
    So when defining a sprite you start at 0,0 if you do $8000 + 13bit angle then it will draw a line from 0,0 in that direction. If you did $4000 + 13bit angle then it will draw a point and the next vector will be drawn from there.
    After the angle and type is defined the length of the vector.
    The example from the demo of a triangle:
    vecdef              word    $4000+$2000/3*0         '    draws a point at an angle zero degrees (notice * 0) from 0,0
                            word    50                               '    a distance 50 away
                            word    $8000+$2000/3*1+1    '    draws a line at an angle of 360/3 degrees from that point
                             word    50                              '    of length 50
                            word    $8000+$2000/3*2-1     '    draws a line at an angle of 2/3 360 degrees from that point
                            word    50                               '     length 50
                            word    $8000+$2000/3*0        '     finishes with another horizontal line (angle 0)
                            word    50                               '    length 50
                            word    0                                '     finish vector sprite
    All angles are from the horizontal CCW. 0,0 in the sprite is the point that will be positioned at x,y as defined in the command vec.
    If you draw your spokes comming out from 0,0 then any rotation will make them rotate around their centre.
    Please do some experimentation and do actually read what is in graphics.spin to better understand it.
    Graham
    p.s. The pointer in my program is a vector sprite.
  • agrossagross Posts: 5
    edited 2007-10-26 00:07
    I have been trying to draw an octagon using the pub.vec method but I am confused about how the angle is calculated the "$2000/3*1+1" makes no sense to me why nit just use the number 4? I have been experimenting with other whole numbers to divide by but I need an angle of 270 degrees and with the formula stated before I cannot use floating point numbers, What magic numbers do you have to get 360 degrees around a point?
    edited 2007-10-26 00:27
    the divide and multiply are done before the addition so it is ($2000/3*1) + 1
    The angle is stored in 13 bits, this is %1111111111111 or $1FFF
    zero represents both 0 degrees and 360 degrees so $1FFF represents just less than 360 and $2000 (which is $1FFF + 1) represents 360 degrees as well numerically but cannot be used because it is more than 13 bits however it can be divided up and used like in this case. The +1, and -1 used are to ensure that the total comes to 180 degrees, the total angle within a triangle accounting for the lack of fractional values I think.
    Graham
  • Martin HebelMartin Hebel Posts: 1,239
    edited 2007-10-26 02:00
    Aaron,
    I've been fooling around a bit, here's what I came up with for some spokes. I converted to 360 degrees to make it easier to read at a cost of resolution for angle.
    -Martin
      repeat
          gr.colorwidth(3,2)
       repeat k from 0 to 359
         gr.clear
         gr.vec(0, 0, 100, $1fff * k / 360 , @vecdef) ' draw angle converted to 360 (much resolution loss)
         gr.copy(display_base)
         waitcnt(clkfreq/100 + cnt)
                               ' ALL angles are with respect to center, not last point
                               ' All  distances are from center as well
    vecdef               word    $4000  + ($1fff * 0 / 360)   ' set a point at 0 degrees from center
                            word    30                           ' at distance of 30
                            word    $8000 + ($1fff * 0 / 360)    ' draw a line of 50 at 0 deg from center
                            word    50
                            word    $4000 + ($1fff * 30 / 360)   ' set a point 30 degrees from center, distance 30
                            word    30
                            word    $8000 + ($1fff * 30 / 360)   ' draw a line 30 degrees off from cente, distance of 50,
                            word    50
                            word    $4000 + ($1fff * 60 / 360)
                            word    30
                            word    $8000 + ($1fff * 60 / 360)
                            word    50
                            '  up to 330 degees.........
                            word    0
    An alternate means to use one line draw at various angles from your loop:
      repeat
          gr.colorwidth(3,2)
         gr.clear
         repeat i from 0 to 360 step 30  ' draw a vector every 30 degrees based on k + i
              gr.vec(0, 0, 100, $1fff * (k +i) / 360 , @vecdef) ' draw angle converted to 360 (much resolution loss)
                            word    50
                            word    0                                       ' end of defination
    StampPlot - GUI and Plotting Software
    Southern Illinois University Carbondale, Electronic Systems Technologies
    Post Edited (Martin Hebel) : 10/26/2007 2:11:45 AM GMT
    edited 2007-10-26 22:30
    Graham Stabler said...
    ...... you can draw circles as deSilva suggests ...
    NEVER DID I SUGGEST SUCH A THING!
    What I hinted to was a not very popular creative use of arc, such as:
      centerX := 100
      centerY := 100
      length := 50
      repeat
        repeat angle from 0 to 360
          gr.copy(...)
          gr.clear      ' line  got lost during posting - will make it much more instructive!
          gr.arc(centerX , centerY , length, length, angle*$2000/360 ,  0,  1,  3)
    Post Edited (deSilva) : 10/29/2007 5:17:48 PM GMT
    edited 2007-10-26 22:45
    Well you didn't make it clear what you meant. As he wants to animate the wheel I did not see a reason to make a filled circle.
    Looks like I need to upgrade my graphics.spin it doesn't even have an arc command.
    Graham
    edited 2007-10-26 23:50
    zooms said...
    ... and I am trying to draw a vector based on a starting point, angle, and magnitude.
    That was his first posting, and I try to stick close to the requests nowadays smile.gif
    But - oops - did I delete the gr.clear as well? Sorry, the gr.clear should have stayed in it... darn on the fly editing of working code.
    edited 2007-10-26 23:51
    Shame it sailed over his (and my) head :P [noparse];)[/noparse]
    Graham
    edited 2007-10-29 14:59
    thank you all for your help. another student, my professor, and I figured it out. in case your courious my project is to make a simulation of an old fashion musical tuner (the kind that uses a spinning wheel that spins at the eye's refresh rate when you're in tune). now i just have to work out the hardware, it should be easy though.
    zooms said...
    Indeed gr.arc(centerX , centerY , length, length, angle*$2000/360 , 0, 1, 3)
    is not trivial...
