Strange looping behavior or a hardware problem?
Not sure what is causing my BoeBot to do this - After installing the whiskers as instructed in activity 3 of Chapter 5 of the Robotics with the BoeBot text the robot is doing some strange things. When first started it will roll forward, respond appropriately when a whisker encounters an object once or twice then it will start simply rolling forward, stopping, rolling forward again, etc. Each time it rolls forward it will beep as per the FREQOUT command in the initialization portion of the code.
So it seems it is looping a bit then going back to restart the program from the beginning (no FREQOUTs anywhere but in the initialization part of the program). I have checked the servo centering and it is fine. Can someone point me in the right direction to understand this problem? I can provide code if necessary.
tom
tom
tom
