I2c Pull Up resistors
SX28 at 4_000_000
AT24C04 I2C EEPROM
SX tech board onboard 5V regulator
How do you decide what value to use for pull up resistors on a I2C device - SDA SCL lines.
The example in the SX/B help file uses 4.7 K but I have seen several examples that use 2.2 K
How would I decide witch is better or does it matter.
I've seen 10K to 1K values used.
Bean.
My goal is to live forever...Or die trying.
www.hittconsulting.com
-Kris
On longer bus lines, lower pull-up resistors, or several resistors in parallel distributed along the bus and at both ends help to also reduce any unwanted reflections.
Greetings from Germany,
Günther
That was an excellent explanation. I had wondered about that too. Thank you!
John J. Couture
San Diego Miramar College
ww1.microchip.com/downloads/en/AppNotes/01028B.pdf
thank you for this link. Besides information about pull-up resistors it contains other interesting information about serial I²C EEPROMs.
Günther
