Robot Lerching at 45 % power
·Hi all,
I just completed hooking my HB 25's to my robot and with expermenting with foward and reverse motions, the foward motion seems to lerch. Slow speed then fast speed ?
In reverse the motion is constant and no abnormal speed is seen. The motors are 7.5 constant rotation motors.
Has anybody had this problem ?
·Thanks,
·Rob7
·Thanks,
·Rob7
I have not been home, I live near Rainbow, and have been volunteering at the Red Cross station near my home.
Several thousand displaced families here.
The 7.5 is the Battery voltage.
I repleyed on this post http://forums.parallax.com/showthread.php?p=685933
·Rob7
I looked over the power distribution pcb I created and everthing looks good.
Chris,
"I failed to overlook one small item !"
I know what you are thinking ?, "Reading the manual"!
Yup,
Well in my code, I had entered two pause lines witch caused my motors to "Run, Stop, Run, Stop".
"Sometime the answer is right in front of your face !"
Well I missed it the first time.
I learned that the timeing of the HB-25 is very important.
Rob7
