Problem with calling other objects
· Being pretty new on the Propeller I have written a main program calling an method·called "screen"·
· in· another object called "domotic screen"
· "Screen" consists of several text strings which have to be displayed
· To do so I included another object in "screen" called "Print_string_char"
··This won't work. It works ok when I put the "print_string_char) as a PUB in the screen object.
· I can't figure out what·I ·am I doing wrong.
·Please help
· Here is the code:
· {Maincode:}
Obj
···· ·Domotic_Screen·· :"Domotic_Screen"
CON
··· ·_clkmode = xtal1 + pll16x
···· _xinfreq = 5_000_000
VAR
· long· bitmap_base
· long· bitmap_longs
PUB start
· Domotic_Screen.start
· Domotic_Screen.screen
"' "Domotic_Screen".spin
CON
· _clkmode = xtal1 + pll16x
· cols = 64
· rows = 48
· tiles = cols * rows
· spacetile = $8000 + $20 << 6
· bitmap_base = $4000
· display_base = $6000
· w_x = 40
· w_y = 30
· w_left = w_x * 16
· w_right = w_left + 256
· w_top = (48 - w_y) * 16
· w_bottom = w_top - 128
OBJ
· vga······ : "VGA_1024x768_Tile_Driver_With_Cursor"
·· pr······· : "Print_string_char"
VAR
· long· col, row, color, width, height
· long· boxcolor, boxptr
· long· array[noparse][[/noparse]tiles/2]
· long· cursor[noparse][[/noparse]1+32]
· long· cursor_x, cursor_y, cursor_col, cursor_def
PUB start | i, j, k
· vga.start(16, @array, @vgacolors, @cursor_x, 0, 0)··· ' Up to here it seems to work
PUB screen···························································· ' This does not anymore
· ·pr.printchar($100)················································ ' Pr refers to Obj Print_string_char
·· row := 0
·· col := 13
·· color :=4
·· pr.printtext(string(" This is a test string"))
DAT
· propeller long
· long %00000000_00000000_00000000_00000000
· long %01111110_00000000_00000011_11111000
· long %11111111_11110001_10111111_11111110
· long %11111111_11111111_11111111_11111111
· long %01111111_11111101_10001111_11111111
· long %00011111_11000001_10000000_01111110
· long %00000000_00000011_11000000_00000000
· long %00000000_00000001_10000000_00000000
· long %00000000_00001111_11110000_00000000
· long %00000000_01111001_10011110_00000000
· long %00000001_11110011_11001111_10000000
· long %00000011_11100011_11000111_11000000
· long %00000111_11000111_11100011_11100000
· long %00001111_10000111_11100001_11110000
· long %00011111_10000111_11100001_11111000
· long %00011111_00000111_11100000_11111000
· long %00111111_00001111_11110000_11111100
· long %00111110_00001111_11110000_01111100
· long %01111110_00001111_11110000_01111110
· long %01111100_00001111_11110000_00111110
· long %01111100_00011111_11111000_00111110
· long %01111111_11111111_11111111_11111110
· long %01111111_11110000_00001111_11111110
· long %01111000_00000000_00000000_00011110
· long %01100000_00000000_00000000_00000110
· long %00111100_00000000_00000000_00111100
· long %00001111_11110000_00001111_11110000
· long %00000011_11111111_11111111_11000000
· long %00000000_00011111_11111000_00000000
· byte 15,15
· vgacolors long
· long $3C043C04······ 'lt grey on dk grey
· long $3C3C0404
· long $C000C000······ 'red
· long $C0C00000
· long $30003000······ 'green
· long $30300000
· long $0C000C00······ 'blue
· long $0C0C0000
· long $FC00FC00······ 'white
· long $FCFC0000
· long $FF80FF80······ 'red/white
· long $FFFF8080
· long $FF20FF20······ 'green/white
· long $FFFF2020
· long $FF28FF28······ 'cyan/white
· long $FFFF2828
· long $C0408080······ 'redbox
· long $3010F020······ 'greenbox
· long $3C142828······ 'cyanbox
· long $FC54A8A8······ 'greybox
· long $3C14FF28······ 'cyanbox+underscore
· long $F030C050······ 'graphics colors
··{ Print_string_char.spin}
OBJ
· vga············ :"VGA_1024x768_Tile_Driver_With_Cursor"
CON···················
· cols = 64
· rows = 48
· w_x = 40
· w_y = 30
· w_left = w_x * 16
VAR
· long· array[noparse][[/noparse]tiles/2]·
· long· cursor_x, cursor_y, cursor_col, cursor_defPri
PUB printchar(c) | i, k
· case c
··· $0D:··············· 'return?
····· newline
··· $20..$FF:·········· 'character?
····· k := color << 1 + c & 1
····· i := $8000 + (c & $FE) << 6 + k
····· array.word[noparse][[/noparse]row * cols + col] := i
····· array.word[noparse][[/noparse](row + 1) * cols + col] := i | $40
····· if ++col == cols
······· newline
··· $100:·············· 'clear screen?
····· wordfill(@array, spacetile, tiles)
····· col := row := 0
··· $101:·············· 'home?
··· $108:·············· 'backspace?
····· if col
······· col--
··· $110..$11F:········ 'select color?
····· color := c & $F
PUB newline | i
· col := 0
· if (row += 2) == rows
··· row -= 2
··· 'scroll lines
··· repeat i from 0 to rows-3
····· wordmove(@array.word[noparse][[/noparse]i*cols], @array.word[noparse][[/noparse](i+2)*cols], cols)
··· 'clear new line
··· wordfill(@array.word[noparse][[/noparse](rows-2)*cols], spacetile, cols<<1)
PUB printtext(ptr)
·· repeat while byte[noparse][[/noparse]ptr]
··· printchar(byte[noparse][[/noparse]ptr++])·······
·Please help
· Here is the code:
· {Maincode:}
Obj
CON
VAR
· long· bitmap_base
PUB start
CON
· cols = 64
· rows = 48
· w_x = 40
· w_y = 30
· w_left = w_x * 16
OBJ
VAR
PUB start | i, j, k
·· row := 0
·· col := 13
·· color :=4
DAT
· propeller long
· byte 15,15
· vgacolors long
· long $3C3C0404
· long $C0C00000
· long $30300000
· long $0C0C0000
· long $FCFC0000
· long $FFFF8080
· long $FFFF2020
· long $FFFF2828
OBJ
· cols = 64
· rows = 48
· w_x = 40
· w_y = 30
· w_left = w_x * 16
VAR
· case c
····· newline
······· newline
····· if col
······· col--
PUB newline | i
· col := 0
··· row -= 2
··· 'scroll lines
··· 'clear new line
PUB printtext(ptr)
The way to do the "shared objects" is to change the declarations of the variables from the VAR section to a DAT section since VAR storage is "per instance" (it's duplicated for each instance of the object) while DAT storage is allocated once for all instances of the object.
The idea is to have a short main program from where i call several other objects including a print routine to display results.
This is as I have understood so far the strong point of object oriented languages.
I will continue with calling all objects from main and use declarations to DAT storage . Let's see what happens>
Rudy Wempe from Holland.
