Sharing Emic Between 4 stamps? — Parallax Forums
GuidoGuido Posts: 195
edited 2007-10-24 04:47 in General Discussion
Is there a way to share a Emic between several Stamps.....I tried the usual serout hook-up with resistors, like between Stamps....But the Emic Don't like it?
Thank You
Guido
  • JonnyMacJonnyMac Posts: 9,556
    edited 2007-10-22 23:50
    You'll have to make sure that the Stamps don't try to talk at the same time, and you should use an open baud mode (see SEROUT for details).
  • DgswanerDgswaner Posts: 795
    how about attaching the E-mic to only 1 stamp then have the other stamps connected to the e-mic stamp with a serial connection. the one stamp will act as a go-between for the other stamps.
    A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
