Passing Parms to Cogs
Ok; I'm obviously missing the point on something. How do you pass a parameter from one cog to another ? I see some examples, but they seemed to be running it through a communication path. I was looking to have my controller cog request (and receive) a value from my sensor cog.
If the question is painfully stupid, point me at the article. I'm writing the code prior to getting the board so all this is a theoretical process so far.
If the parameter is an initial value only, it can be passed using the COGNEW/COGINIT call (see the manual). If you're using an assembly routine, you can store the value in the assembled code before it gets copied to the cog's memory using the COGNEW/COGINIT. If it's not just an initial value, it depends on whether your routine is written in assembly or in Spin. In Spin, you just reference the same variable(s) from the two (or more) cogs. In assembly, you generally pass the address of a common area in main (HUB) memory to the assembly routine and the assembly routine uses RDLONG/WRLONG and their variants to access the value(s). Check out some of the I/O drivers in the Propeller Object Exchange. Many of them deal with this issue. Look at the Propeller Education Lab tutorials (see the "sticky" thread on these at the top of this forum's thread list).
If you have complex information to communicate back and forth, you will need to look at the LOCKxxx instructions in the Propeller Manual. These are needed if two different cogs access the same variables at the same time. In special cases, like sharing a common buffer with one cog putting things in and the other taking things out, you probably don't need to use these (LOCKxxx), but, in most other cases, you will need to use them. See the manual for examples of their use.
Once you figure how that works, you will be well along the way.
