VGA Connector Question
![mynet43](https://forums.parallax.com/uploads/userpics/680/nC6JG6W1TRY21.jpg)
I'm designing a Propeller board with a VGA connector. My goal is to use only 3.3V power.
I noticed that both the Demo Board and Proto Board schematics show +5V connected to pin 9 of the VGA connector.
When I looked up the spec for the pinout of a VGA connector, pin 9 is shown as not connected to anything.
Does anyone know why they're using +5 volts on this pin?
If it's not needed, that will solve my problem.
Thanks for your help.
Jim
Jim
VESA DDC compliant monitor connector
If your computer graphics card has plug-and-play monitor support, then your computer has a VESA DDC monitor connector. VESA DDC standard defined that monitor connector pin 9 can be used as optional +5V 300 mA power supply from graphics card to monitor (the VGA connector ground is at pin 5). The standard does not define that there must be +5V supply at that pin. If you are making small circuit for just yoour on computer, you might want to check this option.
Remember that the VESA DDC standard demand the devices which take power from th graphics card use special VESA DDC modified version of DB15HD connector which guarantees the correct plug-in sequence of power ground and signal pins.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
The only use for this connector is for debugging output to a small LCD monitor. It's been working fine with the old-fashioned DB15 connector, so I assume it'll work without the +5V. Let me know if you think this is a problem.
@Sid
The only things I'm driving on this little board are the Prop and a TI Sound Codec Headphone Amplifier, so I don't think it will use enough power to overheat.
I'm using a surface mount regulator with 800ma output.
It worked fine, with a nice clear display.
I think I'll go ahead without the +5 for this design.
Thanks Mike for clearing up the spec for that pin. It sounds like it's usually not needed for Propeller applications. Although there's an interesting point in what you said. Do you know if the Demo and Proto boards use the special connector you described?
Jim
