Serial input into Board of education need 22kOhm resistor or MAX232?
I have a BS2-IC Board of education and i want to input serial data (12V) to the input pins.
From the manual SERIN, it seems like we only need to connect pin 3 at DB9 a 22kOhm resistor in order to step down into TTL voltage.
But somebody told me that a max232 (with all the resistors and capacitors) TTL to RS232 converter kit is needed.
So what do I actually need? The resistor only or the max232?
Thanks.
Thanks.
