Newbie seeking advice
Hi everyone,
I'm a mechanical engineer who got tricked into developing the electronics for a project, as well as the mechanical system. I have a basic understanding of analog electronics, plus some experience programming a BASIC Stamp that someone else had put together for me. So I've never picked out chips and components and accessories. I think I want to use a Propeller chip. Here's my basic project: I'm going to have 10 light variable resistors and two stepper motors. The stepper motors move a little shade that tries to shield the light sensors from the sun as the sun and the whole platform move around. It would also be nice to have a little LCD display, or maybe even the 2.5 inch display on the Propeller products page for showing the system status. The stepper motors come with controllers attached, I just need to be able to communicate with them via RS485 serial connections.
I'm thinking that the best plan is for me to buy the Propeller Education Kit, do a few demo programs, work everything out, and then move to a ProtoBoard or a PropRPM for the final project. Does anyone have example circuits for A/D conversion for the light sensors? Do I just build a little RC circuit and time the hi-low transition time? And can you recommend an RS 485 driver chip, since I believe I will need one or two of them?
Sorry that I'm a little out of the loop with techie electronics terms. Although I find this project a little scary, I'm looking forward to being a little more electronics-savy when I'm done!
Thanks!
Emily
Thanks!
Emily
Sounds like an interesting project. I definitely would recommend working on each of your subsystems at a time and understand them individually before tackling the entire project. Since the SPIN language allows you to create objects, I would try to create an object to model each of your physical devices in software, then create your larger program to control those objects as a system.
RS485 is a differential signalling protocol, which means you have two wires (A and
For reading the sensors, the method you use depends on how fast you need to read them. In this case it seems you don't need very fast response time, so measuring the RC time should work for you.
In order to observe what's happening in your program, I would suggest trying the Prop Terminal in the Object Exchange. It allows you to send information back to your PC and display it on the screen. This will allow you to move forward more quickly without having to deal with video or external display hardware.
Have fun!
Ken
The more I know, the more I know I don't know.· Is this what they call Wisdom?
Thanks for the help!
Emily
Be sure to run through the Ed Kit Labs. I think that the Counters Lab will be particularly useful for your light sensing.
Fred
I'd use an RS485 driver chip. They add signal conditioning that would be important if you have any significant distance between the Propeller and the motor controllers. In addition, they add a layer of protection for the Propeller's I/O pins. Here's one example: www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1007,C1017,P1713.
These are short circuit protected, protected against static discharge to 15KV, and overvoltage to 60V. They also run off the Propeller's 3.3V supply. Other manufacturers make similar devices.
Have a look at the Microphone to VGA demo program in the Propeller Object Exchange. It uses the ADC technique demonstrated in the counters tutorial for the PEK. There are some other objects in the Object Exchange that also demonstrate this. The circuit is shown on the Propeller Demo Board schematic for the microphone input.
Post Edited (Mike Green) : 10/19/2007 6:23:30 PM GMT
I will look at the Microphone to VGA demo this evening.
en.wikipedia.org/wiki/Rs485
It looks like you have gotten some great advice from others. It also sounds like you have a good idea of what the project needs to do. I would add that you should be sure you write down specific details in a design document before you begin coding. As you create the design document you might add tidbits of code or references to materials online, in the forum, or from the education labs.
For my projects (work or hobby) I need to be sure to write down what I want to do, otherwise I lose track of where I am going or get caught up in the details without seeing the big picture. Especially with the Prop, I need to plan out how each object works together and what informations needs to be shared between cogs.
Timothy D. Swieter
tdswieter.com
One little spark of imagination is all it takes for an idea to explode
Practical Electronics for Inventors:
www.quantumbooks.com/p/06CONS/0071452818
K
