Problems with XGSBMP and Spectrum TV driver [SOLVED!]
Using XGSBMP, I converted the first BMP into a SPIN file. Using find and replace, I changed all the colors from bytes to 1 bit each (which is what the Spectrum driver needs) and changed lines to words. I thought that it would work okay. It did... sorta.
As you can see in the other picture, it's kinda distorted... groups of 8 or so pixels are shifted to the left or to the right. I'm trying to figure out wherein the problem lies, but I can't be sure.
I've attatched a copy of my code. Can anyone else see any obvious problems?
Post Edited (Spork Frog) : 10/19/2007 1:59:57 AM GMT
