Power Questions
Hi all,
I am designing a battery powered device and have I have a couple questions.
First because this is a battery powered device, I need to know the battery level. So what is the easiest way to detect battery voltage with the propeller?
Secondly this device has to be shutdown properly. So the propeller has to be able to control it's power supply, so it can turn off when its done. How would I go about doing this?
Any ideas would be great.
-Kit
-Kit
I almost forgot, for battery level, I use an ADC
Post Edited (Ale) : 10/18/2007 5:39:08 AM GMT
Power switching is always a problem since you don't want the switch to consume much current and, when the processor shuts off its own power you don't want glitches as the Processor's own power drops below where it's working reliably, etc. There are some low dropout regulators with a power enable terminal that reduces the regulator's power consumption to the microamp or even nanoamp level. To turn the system on, you'd have a pushbutton that would pull up this enable pin by charging a capacitor that would hold the enable pin high for a while even if the pushbutton were released. Once the Propeller were to initialize itself, it can set one of its I/O pins high which would keep the enable pin high through a 220 to 470 ohm resistor. To turn itself off, the Propeller would just have to set the I/O pin low. This would discharge the capacitor, drop the enable, and the supply voltage would drop. Eventually, the Propeller's brown-out circuit would force it into reset.
You could try to keep the Propeller running. If you switch to the RCSLOW clock and stop all the cogs but one, then have that sit at a WAITPNE waiting for an I/O pin to be brought high (by a power on pushbutton), the current consumption would be on the order of microamps. If you use a regulator with a very low quiescent current and low ground terminal current, you might do well enough to just let it run.
Post Edited (Mike Green) : 10/18/2007 6:36:31 AM GMT
However when you do not use a precision ADC - or have an independent voltage reference for it - it is of not so much relevance where within (or even a little bit "without") 3.0 to 3.6V the Prop runs!
What value capacitor would be needed for the 'charging capacitor' ?
