Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
EDE -1144 Keypad Encoder IC — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Learn with BlocklyProp
Dipen
3
2007-10-17 16:06
edited 2007-10-19 15:41
in
Need BS2 code for EDE-1144 Keypad Encoder IC
pwillard
321
2007-10-17 17:36
edited 2007-10-17 17:36
You would just need to read the KEPAD ENCODERS RS232 output using SERIN since the encoder sends keypresses as Serial ASCII. You would need to create a translation table in BS2 code that matches your keypad so you can make sens of it.
Ascii <-> Keypad #
48 = "1"
52 = "2"
56 = "3"
49 = "4"
53 = "5"
57 = "6"
50 = "7"
54 = "8"
65 = "9"
55 = "0"
To get started with testing the output of the encoder, you could use SERIN @ 9600 Baud (make sure encoder is at 9600):
serData var byte
myloop:
Serin 1,16468,[noparse][[/noparse]serData]
debug serData
pause 500
goto myloop
Then map the ASCII received in serData to the keypress you want to catch.
There's nothing like a new idea and a warm soldering iron.
Parallax Engineering
14,406
2007-10-19 15:41
I have posted code for the EDE1144 several times in the past. Use our Google Search to find it by searching for 'Chris Savage EDE1144'. Take care.
(A couple of links)
http://forums.parallax.com/showthread.php?p=594468
http://forums.parallax.com/showthread.php?p=641089
Post Edited (Chris Savage (Parallax)) : 10/19/2007 3:46:07 PM GMT
Sign In
Register
to comment.
Ascii <-> Keypad #
48 = "1"
52 = "2"
56 = "3"
49 = "4"
53 = "5"
57 = "6"
50 = "7"
54 = "8"
65 = "9"
55 = "0"
serData var byte
myloop:
debug serData
pause 500
goto myloop
(A couple of links)
