Antistatic wrist straps advice
Hi everyone,
I've been working with exposed Basic Stamps, MOSFETS and similar devices which can potentially be damaged by static discharges, and so I think it's probably best if I start adhering to some sort of anti-static routine. I believe I need at least an antistatic wrist strap, and maybe some ability to remove any static from my soldering iron too(too hot to touch whilst weating my wristrap). I need some advice on how I should use an antistatic wrist strap and what I should connect it to.
I'm really ignorant when it comes to what I need, but maybe some possible grounding points I have access to are: a regulated linear lab power supply(3-15V) which I use to power my circuits, a computer case and my garage tin shed which is bolted into a slab of concrete. Up to this point I have been regularly tapping the computer case and my shed wall every so often, in the hopes this would dissipate any static, but I have no idea if this is actually working.
Some knowledgeable advice on theses issue would be very much appreciated.
Post Edited (BobLowry) : 10/17/2007 10:07:37 AM GMT
What is really more important that every is at the same potential. Even if that is not ground.
In other words, if the bench is charged to 1000 volts, and you are charged to 1000 volts then that is not a problem.
Since most object disapate charge they will eventually be at ground potential.
A conductive work mat that is connected to the wrist strap is a good idea. Connecting the mat to a ground connection (you supply might have one) is an even better idea.
Make SURE you wrist strap has a 1 meg resistor in it. Otherwise you could get a nasty shock.
Bean.
My goal is to live forever...Or die trying.
www.hittconsulting.com
Post Edited (Bean (Hitt Consulting)) : 10/17/2007 3:21:59 PM GMT
If you are grounded and don't include a 1meg resistor, your hardware may be safe - but you are in danger of a serious shock if you touch the wrong hot wire [noparse][[/noparse]like AC].
High humidity and floors without rugs go a long way toward removing static. Winters in the north create problem conditions.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
I have a grounded soldering iron. Radio Shack sells these and anti-static wrist straps as well for under $10 each. Also a Ground Fault Circuit Interrupter (GFCI) is a nice device to have added to your workbench outlets. It is designed to cut the power if too much current is leaking (possibly even through your body) to a ground connection rather than the neutral wire. You can get these for under $10 as well.
CMOS devices can be very sensitive to static charges… so much so that touching an exposed wire or metal connection can be seen as a change in logic state! Other devices are not so sensitive but almost all can be permanently damaged by a high enough voltage difference. If you tend to receive a small shock when you touch metal objects you will definitely want to consider some form of static protection!
- Sparks
Interesting...
- Rick
http://www.radioshack.com/sm-electronics-anti-static-service-kit--pi-2102871.html
Whit+
Post Edited (Whit) : 10/19/2007 3:04:30 AM GMT
I have a small company that makes some LED lighting products.· Our circuits boards are built and burned-in by a contract manufacturer and we receive them in nice little pink plastic bags.· But once we receive them, we don't pay much attention to static issues and we install them in the product and ship.· Being a mechanical engineer, I didn't pay a lot of attention to static related failures in the design stage.· But it hasn't seemed to matter.· We've had units in the field for a few years now with no failures.· Did I just get lucky?
Chris I.
In some cases, MOSfet transistors - like the 2N7000 are provided with a protective resistor of a few hundred ohms. The resistor is not absolutely needed in the circuit, but it is there for protection from the outside. The Art of Electronics has some discussion about this.
In the realm of marketing, it is quite attractive to have everything wrapped in static protection. The customer feels more confidence in the delivered goods, unlikely to try to return as defective, be more loyal to the supplier, and may even accept a greater cost. But on the downside, all those warnings really enhance doubts in ones personal abilities. Ideallly, all components should be tested upon receipt to verify they haven't been damaged by static, but I am sure that I have only tested about 50% of what I have on hand as the low cost itmes, I accept the risk. If you have been receiving tousands of one componet, a statistical sampling of a small portion is standard proceedure for quality assurance. in other words, you try to catch probles at the delivery rather than months later.
I must say that in Taiwan, the over-the-counter service handles product very roughly - no static protection, bent pins, tossed together in to cellophane bags and stapled shut. Still, I haven't gotten a bad device in all the time I have been here. The high humidity and lack of carpets are preventative.
I also suspect that the early stories of failures were part of an intial phase in product development and that devices may actually be less prone to mishandling due to improved design and better handling in production.
