12v battery advice...
well guys its been a while sence I last posted.. all my robot studies had to take back seat to work for a while. well the last 5 months really. anyway im getting close to the end of my projects and my time is freeing up..
I have a bot i have been trying to work on for the last 6 months. I have a 4 wheel rover with 12v motors. I have a propeller chip that I have been learning how to program and have have wazoos of sensors I will add over time. whil the bot is much bigger than a boebot.. its not hudg.. its a lynxmotion 4w. so space for 12v battereys has been on my mind for a while now. lead acid has loads of power but also loads of weight.. anyway I was looking around on ebay to see what I might find and found this..
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=190154058334&ssPageName=STRK:MEWA:IT&ih=009
I wondered what yall think of this? its cheap and 1800mA which I believe will do. the 12v motors at peak are about 400 mA and all the other stuff I doubt will draw more than 400mA .. even if it did current draw would only be high for micro seconds at a time. .. maybe I would use 2 of them?
please post thoughts and comments.
IC layout designer
Austin Texas
IC layout designer
Austin Texas
[*]Brand New
[*]Capacity of Battery: 1800mA
What they are not telling you is at what rate of discharge this is at
Duration of Power up to 8 hours........at what rate are they talking about
Compact DC 12V
Input voltage: 12.6V
Output voltage: 12.6V - 10.8V
Size: 98 x 60 x 23mm
··Thanks for any·
Sam
IC layout designer
Austin Texas
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=300159420059
I'm the person selling these by the way...
Bean.
My goal is to live forever...Or die trying.
www.hittconsulting.com
Post Edited (Bean (Hitt Consulting)) : 10/16/2007 6:41:13 PM GMT
Actually it turns out there's a curve involved. So at LOW current use rates -- 450 mA -- you may get 4 hours. But at HIGH current use rates -- 1800 mA -- you may only get 30 minutes. The difference is "internal resistance" of the battery, which at HIGH discharge rates will eat up a lot of your capacity. ESPECIALLY for a Lithium battery -- Nickel-Cadmium (NiCad) and Nickel-Metal Hydride (NiMH) batteries have very low "internal resistance" and can discharge very fast with lots of current if you put a very low resistance load on them. Like a paper clip -- don't 'short out' a fully charged NiCad with a paper clip, the paper clip will probably melt.
Bottom line -- Lithium batteries are GREAT for 100 mA use in a camera or computer. For driving motors, they're not so good. For $25 or so, you could try it and find out. Just don't think you're going to get 1.8 AMPS out of the poor thing for very long.
so what I would need if I really wanted 1800 mH would be 8 of them.. which is not what I want at all. thanks for setting me stright.
so 2 of these will do the trick?
http://www.lynxmotion.com/Product.aspx?productID=331&CategoryID=48
IC layout designer
Austin Texas
Oh, but to get your 12 volt DC drive, you'll need two of them in series.· That shouldn't be a problem, right?
i just reread the specs on the motor.. its rated for 233mH at peak load and 12v.. so I dont knwo where I was getting the 400mH number. anyway there are 4 of them wired up in a tank tread config.. oh oh.. now I know where I got the 400 number.. it was for both sides of the bot.. see sometimes I have the memory of a gold fish.
ok.. so 466 mh x 2 at peak power = 932mH max, plus sensors and propeller.. really I should be able to get away with
http://www.lynxmotion.com/Product.aspx?productID=64&CategoryID=48
this should run the bot for 45 min's to an hour? or should i just get the bigger ones and deal with the weight?
man I sure can waffle huh.
IC layout designer
Austin Texas
And that 12-volt pack is nice. I wonder what the charger costs?
In any event, yes, you should be able to use that for 45 minutes to an hour of runtime.
IC layout designer
Austin Texas
