VGA Dual PS/2 footprint
In case someone can use it, I have attached an Expresspcb footprint for the VGA Dual PS/2 connector.· This is the connector used on the Proto Board.
This footprint was very difficult to lay out.· Who ever drew the datsheet used 0 as the Y reference, which if fine, but they used Center Line for the X reference.
The part number I used is Digikey 999-H15FA, and the data sheet can be downloaded from them.· I checked and rechecked the footprint and I am quite sure it is correct; however, as with all things, I suggest you check the dimensions before you use it in an expensive layout.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
