updated:June 13, 2008 : PropDOS 1.7b
Oldbitcollector (Jeff)
Requires, SD, ComboKeyboard, and Video
Commands: (Command-line support)
DIR = show files in Virtual Folder [noparse][[/noparse]F1 and % shortcuts to this]
DIR/W = show actual files on SD (wide display) [noparse][[/noparse]F4 and $ shortcuts to this]
DIR *.ext = show files by extension (type dir *.ext)
DEL = delete file (del filename)
SPIN = load/run binary from SD (spin filename)
(filename (without .bin extension will also load/run binary from SD)
CLS = clear the screen
TYPE = display a text file (type filename)
PLAY = load/play an hmus file (play filename)
STOP = stop playing current hmus file
REBOOT = Reboot the Propeller
COPY CON filename = Simple text file creator, exit with Control-Z on a blank line
WPLAY = play 16k-mono & 16bit stereo wav file from SD (wplay filename)
ESC on boot will bypass PropDOS and start the file MENU.BIN from SD if it exists.
HELP = Display list of commands and credits. [noparse][[/noparse]? shortcuts to this]
LABEL <filename.ext> = Assign file to Virtual Folder (creates Virtual Folder if it does not exist.)
[noparse][[/noparse]NOTE: Virtual Folders are simply text files which can be edited.]
CD <VirtualFolder> = Moves view to Virtual Folder (Omit the .DIR when using this)
CD\ or CD.. = Moves from Virtual Folder to Virtual Root/Actual Root. (Depending on compile options)
[noparse][[/noparse]NOTE: In the upper DAT section, there is an option to select Virtual Root, or Standard Root for DIR.]
Download and copy the hmus files on the SD from Andrew's website, and they will load and play.
(Note: you may want to change the .hmus extension to 8.3 format, I used filename.hmu)
link to music: www.andrewarsenault.com/hss/hmedia.html
UPDATED: V1.7b
*This is the GET ORGANIZED Edition. [noparse]:)[/noparse]
Added HELP,LABEL,CD\,CD..,LS, commands.
Assigned [noparse][[/noparse]F1] to display Virtual Folder.
Assigned [noparse][[/noparse]F4] to display all actual files on SD.
Added a PAUSE to DIR/W ([noparse][[/noparse]F4]) at each screenfull.
Removed RESUME command due to maxed ELSEIF usage.
VER command became HELP.
Fixed other minor issues.
NOTE
I've left the 1.6 version attached for those who want the older version.
rename the 1.7b with a .zip extension.
Good Partner Programs for PropDOS
PropCOMM Terminal (Will be updated soon)
PropEDIT: Full Screen Text Editor
FemtoBASIC: COLOR (Uses AIGeneric Driver)
(Hss) Music Player
ETHcomm Propeller BBS Client
PropTerminal w/FILE2SD
tvIRC client (requires enc28j60 device)
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
Post Edited (Oldbitcollector) : 6/14/2008 3:31:28 AM GMT
UPDATED: V1.7b
NOTE
(Hss) Music Player
OBC
I'm working on an image compression format for the Prop too. So maybe we can add support for that later. ; )
Great work!
--Andrew Arsenault.
he'll mind my sharing to this thread..
We came to the conclusion that the .hmu extension isn't a bad idea because of the 8.3 limitation in
the current SD module.
Oldbitcollector
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
Oldbitcollector
I'm going to build myself a SD card reader for the demoboard and give this a try!
Extract and put both these files (binary & music) on your SD.
Startup PropDOS and type: spin swishsyn.bin
(of course play metroid.hmu does the same thing, but not as pretty..
(Code distributed in binary with permission)
Oldbitcollector
Nice work Jeff, Image display would be a great improvement, but it's great as is.
Would be nice to show new users what the Propeller can easily accomplish, barely flexing it's muscles though.
Brian
uController.com - home of SpinStudio
I've been considering something along the lines of a text editor for it next, but
image display would also be very cool. While the program is pretty lightweight,
I use quite a bit of byte space to load 4k-6k .hmus files. I'm considering a method
by which I can pass command-line data to binaries outside of the PropDOS module
itself. It would affect things like the music's ability to play in the background, but
would free up space for other cool features.
Oldbitcollector
I ran this on my Hybrid, it's very good, I especially like the play command....
Thanks!
Coley
Yeah, once I get the Hybrid in I'll convert (Hss) over to it.
At the moment I'm guessing everything plays faster then it should because of the faster xtal xPLL configuration.
Tonal center isn't A=440hz +/- 0.005 cents either I'm sure! [noparse];)[/noparse]
Sort of like the Amiga Trackers when using the VBI (Vertical Blank Interrupt) for music playback on PAL and NTSC systems. *since the speeds are different from the two TV standards (50hz / 60hz)*
--Andrew Arsenault.
Oldbitcollector
Is there a schematic for the wiring connections?
www.fd.com.my
www.mercedes.com.my
(Perhaps we can come up with a good bribe.. [noparse]:)[/noparse]
As for the schematics, I assume you mean the SD card? I've got all the schematics for the
required hardware in the Propeller Cookbook, which can be downloaded from www.uController.com
Oldbitcollector
Well, I'm trying to hook up a standard SD card on the demo board.
I cant seem to get it to work (my first time trying) I'm using PropDOS defaults
I have been working on this forever, I've tried everything...
Here's my pin config.
··· SD Config
··· | 1 2 3 4 5 6 7 8
··· 9
· SD Pin 9 (the one that drops down) NOT CONNECTED
··SD Pin 8 -> 10k pullup - > 3.3v
· SD Pin 7 -> 10k pullup - > 3.3v -> Prop P0
· SD Pin 6 -> vss
· SD Pin 5 -> 10k pullup - > 3.3v -> Prop P1
· SD Pin 4 -> vdd
· SD Pin 3 -> vss
· SD Pin·2 -> 10k pullup - > 3.3v -> Prop P2
· SD Pin·1 -> 10k pullup - > 3.3v -> Prop P3
· Ok, I just noticed I didnot have my SD card pluged in all the way, Ha.. Ha..
· Now it is working just fine !
· These pinouts work correctly.
· So here's the info for someone who is new to SD cards. This works with the defaults
· in PropDOS
· I posted this because I've been trying to do it for 24 hours now... Ha.. Ha, Ha..
· This was much easier to use than DOSonChip!
·Thanks,
··-Areal
I have a tree growing out of my head, but
what do you expect ? I'm a programmer.
I did noticed one thing that DOSonaChip does that PropDOS doesn't; it has a time/date chip.
I was looking at the screen shots from their site. Perhaps I will adopt their directory
format when directories are supported on the SD driver. But for the moment,
I'm hunting for every extra long I have so I can drop that WAV file player in. [noparse]:)[/noparse]
Oldbitcollector
I may be able to simply reuse part of the one I'm using for the HMUS files since one
wouldn't be playing both at the same time.
This is healthy for me, as it will force me to tighten up my code... [noparse]:)[/noparse]
Oldbitcollector
HSS player will sometimes fail after a .wav has been played.
Try setting a flag for the wav player to know when to finish, so it can output a zero, and thus allow HSS to play again.
Baggers.
Also for purchasers of SpinStudio, PropDOS can be provided upon request.
This may save a few new users the immediate expense of a Propplug to get started.
Website for PropDOS now located at www.orrtech.net/propdos
OBC
Just getting started with Propeller?
Propeller Cookbook
PropDOS
I like the idea of being able to compile programs into binaries, load to SD card, and run on a Propeller without the PropPlug. Yes, The PropPlug is easier when frequent changes are necessary. But for a beginner, they can try it out without an extra $30 outlay for the PropPlug.
It's nice to take things on the road too. Say for example you have a electronics club meeting and you want to bring it along, but want to show off multiple programs, just load them all onto your SD card and bring them all!
Brian
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
Version 1.5c here I come!
--Andrew Arsenault.
Been thinking, with having all those fonts why don't you change them to raw files and have them selectable in the dos, ie FONT CBM or FONTBURNRUBBER, which would then just load the new font over the old one [noparse]:)[/noparse]
Just a thought,
Baggers.
completely up to speed on how to change characters on the fly. This is something I'd like to add
for use with my "Femto COLOR" that would allow redefinition of characters for basic games.
Not sure how to handle raw files yet, study of your spectrum driver is on my to-do list.
Working on it.. [noparse]:)[/noparse]
OBC
Propeller Cookbook
PropDOS
Yup, exactly what I did this weekend too! Packed all of my SpinStudio modules into a small box with a power supply, a NES controller, and took the Prop over to the relatives. Looks like my brother-in-law will be joining the ranks of the Propeller-heads this month. Just drop a load of binaries from some of the games in the Hydra section, with some wav & hmus files and you've got a nifty way to demonstrate the Propeller to the others. It sure beats babbling on about what this amazing chip can do over the dinner table to folks who can't begin to grasp what you are talking about.....Boot PropDOS, Spin JETPAC, hand the controller out and watch the fun. (I did)
OBC
Propeller Cookbook
PropDOS
Post Edited (Oldbitcollector) : 11/26/2007 7:32:44 PM GMT
Many tweaks, big fix of not using "SPIN filename.bin" to execute files.
(See top thread)
OBC
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
