WIFI Handing wit propeller
Dear Genius!
If you have any idea how can I connect for example one wifi SD card to propeller and
how can I transfer some bytes to PC and from PC please write me here.
Thank you.
Thank you.
There are some WiFi interfaces, for example the WiPort made by Lantronix, that can be used with the Propeller. You can also use Parallax's memory stick data logger to transfer files back and forth with a PC using a standard USB flash memory stick. There's Rokicki's SD Card I/O routines that will read and write PC compatible files as long as there's only a root directory (the routines ignore any subdirectories).
UART / Digital I/O / Analogue Embedded Wireless (802.11b) Bridge.
Product Code:- WLNB-AN-DP101-G
Product Information
The Airborne embedded module features a fully intergrated 802.11 radio and network processor that provides a complete wireless network connection in a single, small footprint package. Airborne wireless modules provide all of the network protocols and processing needed to implement embedded wireless solutions. They offer industrial-grade performance, making them ideally suited to harsh environments.
Sparkfun also sell these, along with a breakout board.
HTH.
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
WP2001000-02 WiPort about 168 EUR
DC-WME-01T-S DIGI about 270 EUR
Any other WIFI CF or SD card's price is no more than 80 EUR
The more I know, the more I know I don't know.· Is this what they call Wisdom?
Yup, I agree; but it depends if you have any choice!
If the application requires WiFi; if the Prop' can't do it itself (I'd like to see me proven wrong!), and the solution you're designing warrants the cost, then that's the price you'll have to pay
Cheers,
Simon
Craig
"... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." -
"If Python is executable pseudocode, then perl is executable line noise."
"The best accelerator available for a Mac is one that causes it to go at 9.81 m/s2."
"My software never has bugs. It just develops random features."
"Windows isn't a virus, viruses do something."
"Programmers are tools for converting caffeine into code."
"Enter any 11-digit prime number to continue."
The propeller is neat but lacking in memory for anything big and complex.
