My quickie Propeller dev board
So I was in dire need of a proto/dev board for my Propeller DIP-40 that I bought back when it first came out. But I wanted to work with it last week, so I didn't want to order anything. So I went to radio shack, and actually managed to find everything I needed to build one!
The only things you see here that you can't get at radio shack are the Propeller, EEPROM, xtal, and the headers... and the LCD.
Anyway I figured someone might get a kick out of it.
You did well.. that looks simple and a very workable solution to get started.
Well done..
Ron in OZ ... Melbourne
[noparse][[/noparse]moved comment... :]
Sweet job on that impromptu propeller board! My hat is off to you for being able
to piece that together from the source you had. Shopping in that store is a little like
a "junkyard-wars" ("scrapheap challenge" for my euro friends) experience. [noparse]:)[/noparse]
Oldbitcollector
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
No because then you would always find just what you needed
By the way what guage of wire did you use for the machine pin headers
