RC frequency interference
I have two RC·cars with controllers·that operate on 49Mhz,
how do I·hack one of them to work on a different frequency ? do I have to replace the parts or can I somehow fix the frequency of one of them ?
- Stephen
both have 2 analog channels and 2 digital channels
the DataSheet 'http://www.ortodoxism.ro/datasheets/nationalsemiconductor/DS007912.PDF') is there.
also, I dont think the RC signal transmission would effect much. The analog channles support the carrier wave and the digital channles are for the timing (ie pulse width ect.). the frequency is close enough to the amature radio (ham) band 50.0 that no one would notice.
Post Edited (DataFreedom) : 3/5/2008 10:46:39 AM GMT
There are several issues here. First, if you get out of the frequency that is allocated to these things you will be trespassing on the territory of some of other service. There are NO un-allocated frequencies below 2 Gzh! (I don't re-call if there is any "free range" left anywhere above that...
That said, the frequency seems to be controlled by an external tank circuit and its primary component is a crystal. Frequency change would depend on how far you wish to change... Do you have the test equipment necessary to re-tune the transmitter and receiver to the same new frequency?
You say that "the frequency is close enough to the amature radio (ham) band 50.0 that no one would notice" Actually, the only thing that allow you to "slide under the radar" would be the low power transmission of these things. The 50 Mhz ham band is sometimes used by hams for RC, and if you inadvertently shot down someone's plane, he (or she) would be (rightfully) rather perturbed...
Terry
