Momentary:
A ping can give you a two dimentional view of the area. If you want your bot to go in the farthest direction it wouldn't be that complicated. I can give you more info if this is what you want.
OR
Long Term:
If you want to map an area and store it for future use, it is quite a bit more complicated because you need a lot more memory. There is a thread called Mapping Concept in the sandbox.
LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum
LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum
ON subnum GOTO Hope_this_helps, Thanks!, WOW!!
END
OR
Long Term:
LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum ON subnum GOTO Hope_this_helps, Thanks!, WOW!! END
