Powering BS2e
hi i'm looking to build a pcb to use with a bs2e as a stand alone microcontroller, separate from the basic stamp board, however i'm not sure how to power the bs2e, for my projecti'll only require 2 pins - one for listening and the other for outputting a pulsout.· In order to power the microcontroller, should i only use Vss and Vin? or are there any other devices /parts i should put in, as i don't really need a reset button, any advice is much appreciated, thanks
Ideally, you should have high value pullup resistors (like 100K to Vdd) on all unused chip inputs. You could use a multiple resistor pack for that purpose (with a common lead).
