JIDE 2.0.3 can't show message or debug window
I can't get these windows to show.· I call them up through the menu and nothing happens.· Only the focus gets sent away from the main application window but no go.
Tried uninstalling and reinstalling but didn't change anything.
This use to work the last time I went in a month ago.· Any updates to this software?· I only saw the same version available for download.
Anyone else experience this and was able to fix it?· Thanks.
Yves
Yves
Have you tried the IDE beta:
http://forums.parallax.com/showthread.php?p=654012
regards peter
Running XP SP2 and using BOE USB rev. B.
Did I miss another file somewhere?· any part of the registry I can access to reset the application defaults for the windows?
Javelin.zip into·the Javelin Stamp installation folder
(generates Javelin.exe)
and copy Terminal.java to folder <%path%>\lib\stamp\core
Then running Javelin.exe is enough to start the IDE beta.
I think the errors come from the fact that you use a BOEUSB board.
Have you applied the fix to the usb board as descibed in
http://forums.parallax.com/showthread.php?p=656527
The fix is a 1k resistor between SIN and GND on the 24pin socket.
regards peter
Weird how they got to these values but I'm good to go now. Also soldered the 1K and running the beta version of Jide. Thanks Peter, this gave me an excuse to try the new software and implement the BOE mod too.
yves
when the message window was hidden?
regards peter
Oh well. will know next time, nothing lost. Thx again Peter for beta software with very nice additions BTW.
Cheers,
Yves
Thanks for letting me know.
regards peter
