TTL voltage- max cable length run
Sorry to be a pain guys.
I've done some quick searches with no luck.
I'm wondering how long of a cable I can run the·outputs of the·BS2 without amping them.· I'm sure it comes down to wire guage etc...
But for the sake of arguement lets try and use a standard IEEE cable.
Can I run 15-20 feet?
Thank You,
Rob Jackson
oleancomputers.com
Thank You,
Rob Jackson
oleancomputers.com
As long as you're not trying to draw large currents, TTL signals can be reliably used for the distance you mentioned. Keep cables separate from cables carrying motor currents.
Don't forget, the Stamp pins can only deliver about 20 mA by themselves. Ordinary CAT5 cable will work fine, or use #22 stranded if much flexing is expected.
Cheers,
Tom Sisk
Tom Sisk
http://www.siskconsult.com
PJ- I'd rather hear an answer from experience.
Thank You,
Rob Jackson
oleancomputers.com
-Will be trying to run a RC servo - throttle control.
-Pickup a tach signal. still working out the how yet. 0-1800rpms
-And just general solidstate relays.
Thank You,
Rob Jackson
oleancomputers.com
Signal to noise ratio is what will get you in the end. At the extreme end of the cable the RECEIVER is most sensitive to the strong signal of the local TRANSMITTER in two way communications. I didn't see anything about this yet so I figured I'd chime in. Good grounding can keep this under control.
You will have the best luck if using CAT-5 style cable to ground 1 member of a twisted pair and send a signal in the other member of the pair. This will help keep random noise from being introduced or from output signal cross-over from jumping into your input end.
There's nothing like a new idea and a warm soldering iron.
