Multiplexing Help
Hello,
I have 40 led displays, Common Anode. All 7 segments A-G are wired in parallel, i.e. All A's wired together, all B's, C's, D's, E's F's, G's. The 7 segments are connected to a 7447 BCD to 7 Seg Decoder to reduce the I/O Lines needed, and I use a binary nibble. I have been trying to multiplex the displays by turning each display on for a small amount of time then turning it off and going to the next display. Currently I use All the available pins on the Basic Stamp 2P40 and it works Great with 15 displays, but I need a way to control the other 25 displays with one Basic Stamp. What I am looking for is a way to turn on and turn of each display in SEQUENCE so that I can multiplex 40 Common Anode seven segment displays without sacrificing every single input pin on the stamp, and a way that uses minimal amount of pins perhaps a serial connection using shift registers. I was thinking about cascading shift registers to turn on each display in sequence using shiftout, I don't know if that will work, and then there is the question of getting the right amount of amperage so that the displays are bright enough. I would greatly appreciate any suggestions.
-MR
Post Edited (MR) : 10/13/2007 9:37:25 AM GMT
-MR
You will likely need buffering on the decoder (or multiple decoders) and the serial shift register to get the kind of current you'll need for multiplexing that many digits. If you're mostly happy with the brightness with 15 displays, you'll probably be ok with the brightness for 20 displays without significant changes. You could use two 7447 decoders (on 8 pins) plus 20 pins for the selectors and do two displays at a time with a total use of only 28 I/O pins. Don't forget that both the Stamp I/O pins and the 7447 output pins have current limits on them on the order of 20ma.
If both the 7447 and the stamp have 20ma current limit, how would I boost the current to get good brightness?
I thank you for your help.
MR
That brings up another question. 40 displays means that each display will be having 1/40th (2.5%) of the current drive as its average. To achieve 6mA average current per display, that would be a whopping 2.4A of segment drive - check your data sheets, that may not be feasible. Also that's a lot of time consumed on your Stamp program - have you tested it to verify that it scans fast enough to meet persistence of vision requirements?
Maxim makes some nice LED driver chips, that will multiplex several displays together. There are ones available with parallel and serial interfaces. I believe some are cascadeable. You might look into using a few of those to drive your displays instead - that would free up your Stamp's CPU cycles to do a lot of other stuff!
