Starting an autonomous plane project
http://www.parallax.com/detail.asp?product_id=27207
Me and my friends are looking to build an autonomous plane for the state science and engineering fair, and I was wondering if this kit would work for us. We only have experience in mindstorms robotics so this is a huge leap forward for us and we're desperately trying to learn.
I have a couple questions
1) it says we need to power it with a 9V power supply, but can we use a battery instead?
2) will we be able to attach gps/altitude/gyro sensors to this?
3) will the board of education work with this http://www.parallax.com/detail.asp?product_id=29144?
4) assuming we have that motor control product, would we be able to run 4 servos(possibly 5), plus 1 DC motor for the propeller, as well as various sensors?
any suggestions for motors?
5) any suggestions on what else we would need to buy?
Post Edited (skatj) : 10/13/2007 7:11:07 PM GMT
2)Yes, you should be able to attach a GPS (parallax sells one), as for the altitude and gyroes, it depends on the product. Do you have one in mind? Does anyone else have soem that they have used with success?
3) the url must not be right. What is the product called?
Yes, you should be able to control the 4 or 5 servos (you would probably want to get a Parallax Servo controller to offload this from the stamp {you have to send a signal every so often, and this can be a pain.) The dc motor should work fine considering you have a motor controller. (Pololu motor controller, or motor mind B might work well for this.) What size plane are you talking about (RC care size 1ft - 1 1/2ft?)
I have used mindstorms myself and PBASIC is completely different. With mindstorms you don't get into the electronics of everything. I have not heard anything about this kit, but it looks suitable for beginners. Just a heads up.
EDIT: you might want to change the name of the thread to involve a plane (there are a few people who have built planes and you might get their attention if you put that in the title.· Do this by clicking the pencil in your first post and changing the subject line.
So do I have to solder wires to the battery or something? And that one battery can power everything, the servos, the motors, and the board?
I think the question mark broke the link, here it is http://www.parallax.com/detail.asp?product_id=29144 HB-25 Motor Controller
Not sure on the exact size of the plane, but it will be fairly small. Would this be compatible, if not any suggestions for motors?
http://www.redrockethobbies.com/product_p/watt157155.htm
Alright, where can I buy a servo controller, I can't seem to find any on the parallax website. And what do you mean by "you have to send a signal every so often, and this can be a pain"?
Thanks for the help, like you said this stuff is a huge leap from mindstorms, and I am really nervous about screwing something up or buying the wrong products
The PWMPAL can control 4 servos and the Parallax Servo Controller can control 16.
I have no experience with planes so I could not tell what is neccessary.· The HB-25 is typically for larger motor, so unless you are making a large plane the pololu or motor mind B will probably work best.· It all depends on the motor, so choose that first.
Look under the motor controller section for servo controllers.· What I mean·by you have to send a signal every so often is that you do not set the position of the servo and it will keep that position.· You have to tell the servo every so many (40?) instructions the postion that you want it at.· With the servo controller, the servoes become "set·and forget", because it pulses for you.· There is a new project coming out called a servoPal, that goes inbetween the servo and the controller (basic stamp) to keep sending the position signal after the stamp stops.· I hope this clarifies it.
I would order the kit, because then you will understand this a lot better.· You can order the other parts later.
But if you've got $1,000 hanging around for building prototypes and trying things, go for it. Probably you want a 9.2 or 9.6 volt battery pack -- but as has been said, those can be heavy. A 7.2 volt battery pack is more practical for servos. However, I feel SURE there are off the shelf airplane systems with servos, a controller, battery, charger, and RC remote. Hopefully you can 'hack' a large one of those to install a small PC board with BS2, GPS, and accelerometers.
To keep costs down, I recommend Off The Shelf whenever possible. People have been flying hobby planes for a really long time, and you want to take advantage of any mass-production items you can.
Also, it wont be truly autonomous in that it can autopilot to a certain location, our goal is just to get it off the ground and fly around with a preprogrammed flight path. A more accurate description would be "non R/C model airplane". We have a budget of around 350$, possibly more
Does it need a separate battery or what?
Would this brushed motor work with the motor controller? http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWK49&P=V
Post Edited (skatj) : 10/15/2007 3:03:49 AM GMT
I am an experienced electric RC modeler. Trust me on this! Build an electric RC airplane first (an electric high wing trainer from Tower Hobbies would work fine). Learn to fly it well and learn how the components work together. Going autonomous from there will be easy, it is just going to crash a lot and cost a lot of money! Seriously, sticking a basic stamp into the plane and controlling servos in a predetermined sequence loaded into memory is easy. The problem is dynamics. If a gust of wind comes along (and it always will) and lifts a wing the stamp program has no way of knowing that the airplane is already rolled into a turn and it will blindly give a signal to the aileron servo to turn, and now the airplane is upside down! You get the drift, I am sure. To make this work with any reasonable chance of success you need a full set of accelerometers and gyros·for all axis which can tell the stamp what the aircrafts attitude is in the pitch, roll and yaw axis very accurately. Then the stamp program has to figure out how much input based on that information to give the servo to accomplish what it was programmed to do. It is going to have to be a closed-loop system with lots of math going on. The basic stamp is way too slow to have any chancie of handling this. The propeller chip would work great because of its high speed and multiprocessing capability. Worrying about what motor/battery combination to use is down in the minutia compared to other problems you will encounter. Many experienced RC pilots can't handle a gust of wind. Compare their brain's capability to the basic stamp!
A few years back, an autonomous RC plane was flown by amateurs across the Atlantic Ocean succesfully. You could start by reading their story in the AMA archives available at modelaircraft.org. Good luck.
Post Edited (RichardF) : 10/15/2007 12:13:54 PM GMT
Russ
