Which one- BS2 or prop
I am trying to build a robot that will transmit info continuously between a computer and Boe-bot. People have been telling me to use the prop. However, I do not see the point is buying a prop and proto board because all the stamp will do is receive ALL the directions and commands from the computer. The Stamp will just execute them. Why would I need a prop?
-CR
-CR
The major advantage of a Prop in this setting is that it can do this stuff all by itself. It can devote a processor just to handle any number of servos. It can devote a processor to provide a full duplex serial channel with a large buffer should you need it.
Question: How difficult would it be to modify my boebot to use a protoboard instead of a stamp?
