Help with transistors
I am taking apart a missle launcher tank to use as a base for a robot.· I would like to use the transistor array on the ciruit board inside in order to drive the motors.· The circuit board is labeled MSD2003R-1.· There is a row of 8 transistors along one edge.· They are paired with what appears to be 2 pairs per motor.· Each pair has what appears to be 2 different transistors.· One is labeled H 882 4e the other H 772 4f.· I tried googling the part numbers to see their pinouts with no success.· Can anyone help me with that?· Is there a standard for the 3 pins of a transistor?
Thanks in advance for your help,
Mark
Mark
Marty
Lunch cures all problems! have you had lunch?
Thanks again for any help
