PWM 2 motor isolation help
KKDZ28
Not sure where to post this. I'm new to this so please be kind. I need help trying to find the best way to do this since I like to over complicate things. I have a Throttle body motor/servo that I am controlling with PWM. I need to piggyback off the 12VDC signal to control another throttle body motor. My main PWM signal will only power one safe. So I need to make something to use that PWM Signal to run the other Motor/Servo from another isolated driver. Not sure how much is pulls but might should not be more then 3 Amps. Any ideas?
Kris
Kris
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
