Graphical widgets — Parallax Forums
Graphical widgets
Graham StablerGraham Stabler Posts: 2,510
edited 2007-10-13 00:45 in Propeller 1
I'm using graphics.spin for the menu system of my all purpose experiment controller, this unit triggers cameras, rotates stepper motors and generally does all the things required in a number of experiments/instruments.
For one of the experiments an object is rotated and pictures are taken of it at a variety of angles, so I made a little vector sprite of a pointer and a tick, the program now shows a pointer rotating around past the ticks that are located every 10 degrees or so. It struck me the functionality could be generalized into a function that draws a clock and adds the pointer at the required position.
Such generalized functions could form a set of useful graphical widgets to be incorporated into programs, things like progress bars are very simple and there are many other possibilities.
Anyone else done anything like this?
Graham
  • Ken PetersonKen Peterson Posts: 806
    edited 2007-10-12 15:08
    @Graham: I was going to start working on a graphics widget library to be used with a touch screen GUI, but I ran out of memory for the application. So I had to scale back the GUI to use the built-in characters. I might pick up on that again if I end up doing a dual-propeller solution with one propeller dedicated to the graphics.
    The more I know, the more I know I don't know.· Is this what they call Wisdom?
  • RaymanRayman Posts: 16,228
    edited 2007-10-12 15:12
    This is a good idea.· The ~$5,000 NI control system we have uses LabView.· This has a ton of built-in widgets.· It would be nice to have a similar (if more primitive) thing here...
    I think "Graphics" uses a lot of resources though.· It may be better to do it as 4-color tiles.· Still, it would be difficult to do an analog meter or clock face with tiles...
    edited 2007-10-12 15:42
    Actually, now that I think about it... I wonder if NI has considered making a Labview driver for the Propeller. They already do it for the Lego Mindstorms thing, I saw. The propeller seems like a very similar thing, although more flexible.
    Also, M$ has some kind of Robotics SDK that I was looking at a while ago. I think this was geared toward the Lego Mindstorms, but it could also probably be applied the the Propeller I think...
    Using one of these tools, one could make a Propeller based control system that intefaces with a PC in a more advanced way...
  • Sparks-R-FunSparks-R-Fun Posts: 388
    edited 2007-10-12 18:29
    Graham,
    I like the idea. I hope you and others will share premade GUI widgets with us.
    Ken,
    What touch screen are you using?
    - Sparks
    edited 2007-10-12 18:36
    Rayman, graphics does use a cog but apart from that it is very efficient for creating graphical elements because they can be made from vectors, a box is just two co-ordinates for example and can be scaled at will. The creation of widgets as functions means that there is good reuse of code too.
    Graham
    edited 2007-10-12 19:31
    @Sparks: Just any resistive touch screen.
    edited 2007-10-12 23:58
    Graham: I think it also uses 16 longs for every 16x16 tile of the graphics window, right? This could use up a lot of memory for a large display...
    Well those that don't want to have a truly graphical display can find other means, for me I still have plenty of memory left for my applications.
    Graham
