Serial LCD 4 x 20
I have one of the Parallax serial 4 x 20 LCD's and am having some trouble.
My stamp is a 2P40
If I put it in test mode it works so I assume the display is ok.
So I tried a basic example from one of the documents:
' {$STAMP BS2P} 'I added the P as all examples were for a BS2
' {$PBASIC 2.5}
TxPin CON 13
Baud19200 CON 32 'also tried 84 instead of 32
HIGH TxPin ' Set pin high to be a serial port
PAUSE 150 ' Pause for Serial LCD to initialize
SEROUT TxPin, Baud19200, [noparse][[/noparse]"Hello, this text will wrap."]
I get not a sausage.
Well I get some jibberish on the screen when I download and run. This makes me think I am connected to the right pin (got a little confused between Outputs 0-16/labelling etc) It is connected to pin 18 of the 2P40 which I guess if the first bank of pins is called 0 to 15 means I am on 13.
The LCD is set for 19,200.
I do have to admit how I powered it.
The stamp is powered on pin VDD by a 7805 reg with a couple of small filter caps. I have infact powered the display from that connection point and ground.
Is this a major?
Regulator is powering nothing else.
Now having read a bit more I see this is not recommended however as the regulator has 1amp rating I hope all is well.
Can someone see what has gone wrong here?
Cheers
Richard
My stamp is a 2P40
' {$PBASIC 2.5}
TxPin CON 13
Is this a major?
Cheers
Richard
Parallax/Jon Williams published the following which I use in each project so I don't have to remember or look up the rate for the processor I use. You just use BAUD in your SEROUT which is set to the correct value.
' {$STAMP BS2P} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- #SELECT $STAMP #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 TMidi CON 12 T38K4 CON 6 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 TMidi CON 60 T38K4 CON 45 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T4800 CON 813 T9600 CON 396 T19K2 CON 188 TMidi CON 108 T38K4 CON 84 #ENDSELECT SevenBit CON $2000 Inverted CON $4000 Open CON $8000 Baud CON T19K2 ' -----[noparse][[/noparse] Variables ]-------------------------------------------------------Post Edited (Paul Sr.) : 10/12/2007 12:25:34 PM GMT
