The Bytecode
Is parallax willing to give us the spin bytecode specs???
i have noticed this being brought up a number of times, but now i am a little confused. Mainly due to the existance of the GEAR project on sourceforge, which has also been discussed on this forum.
wouldnt the developer(s) of GEAR have needed access to the bytecode details, in order to write the interpreter for the program.
is there now a datasheet that there wasnt before? if so, where is it?
I hear and I forget. I see and I remember. I do and I understand
-Confucius
-Confucius
I think in most cases, Such as with GEAR. It's just been some really good reverse engineering. [noparse]:)[/noparse]
People are smart on this forum and will figure anything out giving time.
--Andrew Arsenault
y'know copyright/blahblahblah
-Confucius
There are some road blocks upstream... [noparse]:)[/noparse]
what is the baud rate/protocol?
-Confucius
http://forums.parallax.com/showthread.php?p=591445
http://forums.parallax.com/showthread.php?p=665019
I think he is the person with the best knowledge of the bytecode at the moment (exept the Parallax people).
But what is your intention with the Bytecode? To use the Spin Interpreter for another language? Or an alternativ Spin Compiler for Linux/MAC?
Anyone offering you such information... other than Parallax... is either a thief or a liar.
how can it benefit parallax? they give away the software freely.
-Confucius
The bytecode has been determined through the efforts of GEAR and by Cliff L. Biffle ( who both deserve much credit ) and I've built my work on top of theirs. Others may have also had input of whom I'm not aware. I know others have worked on things such as Callbacks, determining stack operation and so on ( sorry, cannot give credit without a forum search ).
Bytecode can be determined for any particular Spin construct and a compiler just has to do the opposite. What the Propeler Tool generates can be observed by looking at the image map or a saved .binary or .eeprom file. The initialisation bytes have been documented and can also be created by a compiler.
Apart from one undocumented bytecode I don't see what stands in the way of a third-party Spin Compiler other than getting it done. That one bytecode I don't particularly worry about because if it's not in any code decompiled it doesn't have to be generated by the compiler, and when we do finally find it in some Propeller Tool generated image code it will hopefully be reasonably easy to determine its operand(s) and what it does. That's the same for the 'known unknowns' which have been identified, which are potentially there but have not materialised in actual image code.
Yes, Spin and the bytecode is proprietary, Parallax have clearly said they are not going to document the bytecode and they have put nothing for that into the Public Domain, but there's plenty of reverse engineered information and documentation which is. No, Parallax will probably not confirm the reverse engineering is correct, but that doesn't mean it will not be. The third-party representations of de-compiled bytecode is probably very different to what Parallax themselves use, but that doesn't matter.
The structure and layout of the image code, the way methods are called, the way objects are included and so forth can all be determined by examining the decompilation. The download protocol has been well documented and implemented by third-parties in a number of ways.
I don't really know how to take that, or give an answer to it. Perhaps you could clarify how you mean ?
It's previously been said by Parallax that they will not be documenting the bytecode because they do not want the support issues which would come with doing that ( paraphrased ).
Besides, if they documented everything, where would the fun of reverse engineering come from ?
It can be done by three approaches:
- Use SPIN bytecode
- Use own bytecode (and provide interpreter) , example is FORTH
- Use of a variation of LMM, as "C in work"
I see five problem areas - there are more for sure!
- Speed of SPIN interpreter is not very convincing
- SPIN bytecode might not match well with requirements from different languages
- COG memory is quite low for any other sufficiently powerfull VM
- HUB memory is low for run-time and library systems needed for sophisticated applications
- Common "Operating System Support", as libraries, linkers is totally missing.
I should expect when a running LMM is available (and the interface to it documented), as well as a standard overlay-mechanism (from EEPROM or SD), things will accelerate considerably.
It seems to be a matter of helpful de-facto standards, not so much of workload or feasibility....
The other choice is for a student or group of students to do it as a class or master's level open source project.
It is not so much work as you expect to port one of the free compilers when you have already done it once. Maybe this "community" is a little bit biased to "electronics" rather than to computerscience.
There are two annoying tasks: To really understand the VM (or any intermediate code) - when it is your first contact to that (portable) compiler.
Adding the interfaces to the library system (I/O, memory manegement, arithmetic support, string handling,...)
Writing the interpreter for the VM or a generic code generator is fun (and debugging
Seriously, though, it would make a nice master's level project, and I didn't mean to sound cynical.
-Confucius
There already is an operating system (see the sticky thread for Graham Stabler's Good Thread Index). Not much has been done with it for some time other than incorporate a lot of the routines into the various flavors of FemtoBasic.
And if their real·interest is porting,·they may feel that there·are less difficult hurdles to jump.·
Primarily I believe it boils down to an individual or group having a need or want for that, or ( in rare cases ), is altruistically aiming to provide what others may want or need, or is aiming to engender support for their favourite programming language or provide greater accessibility to the Propeller.
To port a language to the Propeller there are a number of requirements; a good understanding of the language and/or tools being ported, a good understanding of the Propeller Chip, plus the will, motivation and skills to do it. It is likely that this combination hasn't occurred yet.
I've actually been so impressed by Spin ( against my expectations ), that I'm starting to become more interested in porting Spin to other micro-controllers.
The more I know, the more I know I don't know.· Is this what they call Wisdom?
Personally, I find the whole SPIN / ASM combination to be just excellent. The up and coming C compiler is gonna address some wants of mine, but SPIN / ASM will handle the needs.
Half the time, me wanting a feature, or cursing the lack of one, comes down to me wanting to do it the "old" way, or "traditional" way. The Propeller really isn't either of these things. Some time spent thinking, or maybe just away from the problem, often yields some simple solution.
Then there is scale. The current Prop is right at, or maybe below, the scale where other languages and environments make better sense for more use cases. Prop II will hit square into that territory, and that's when we will see a whole bunch of activity on that front.
Do we have some terminology for that aspect of things?
There is the word micro that gets globbed onto computer and controller. Does the same work for mini? As in minicontroller, where a mini is bigger than a micro, but not so big as to warrant some other word, besides controller?
If so, Prop I is a micro, Prop II will be a mini. Languages and such work for minis better than micros.
But why don't they just release it with a huge disclaimer like:
WARNING!
By downloading the Bytecode/VM/DownloadProtocol-Specifications you agree to never ask any questions.
If you violate this rule you will be shot.
Then everyone would be happy...
Hydra in a LEGO NES:
http://forums.parallax.com/showthread.php?p=654788
For one, I'm sure there is no specification that could be released. The way these things are done is that
there are a lot of napkin notes, often with pizza sauce splotches. The napkins are not necessarily numbered
and the notes are for the benefit of the creator and not necessarily written for someone else to read. It's a
lot of work to rewrite the napkin notes into a form for an expert to understand, let along someone without
just the right combination of expertise to understand. People will call and e-mail for further information and
either the creator will have to spend lots and lots of time to document further or have to hire someone
relatively expensive to write it up and still have to devote too much time to answer questions from the tech.
writer.
In any event, everyone will not be happy. It just doesn't happen.
I remember an operating system that I worked on where a lot of time was spent over Pizza Hut food and drink.
The owner even gave us the heavily marked up table cloths since we were such good customers (and did offer
to pay for them). They got hung on the walls back at work as part of the formal documentation.
The part about violence, is not really needed here. just a license "as-is" is just good enough.
OTOH, what for ?.... alternatives will emerge/are emerging.
Edit: Mike, not all businesses are that unprofessional. Some are worst
Post Edited (Ale) : 12/22/2007 10:18:56 PM GMT
Oh well...
Unterwelt (My first game for the HYDRA):
http://forums.parallax.com/showthread.php?p=696204
just wondering if we are just looking for an easy way to the byte code, femtobasic and propdos both have the address of the interpreter.
Parallax Forums - If you're ready to learn, we're ready to help.
