SERIN WAIT question
I need monitor a serial line for strings, for example "@1|dda" and "@2|da".
If I don't get either of these sequences with 30 seconds I need to timeout
from the SERIN command and go on to other things and then come back and
check again later. Is it possible to WAIT for 2 strings using the SERIN command?
If there is data coming in, it will wait forever for the WAIT string.
Bean.
My goal is to live forever...Or die trying.
www.hittconsulting.com
I'm using the stamp as a watchdog to monitor activity on a serial line.
Actually I don't need the timeout option. I just need to make sure that
I receive either of these 2 strings at least every 30 seconds. Any ideas
how to approach that?
You can't WAIT for either of two different strings.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
All of the data coming across begin with a '@' and end with a '#'.
So I guess I could wait for a '@' and receive up to the '#' and then
check the string for what I'm looking for. There is a lot of traffic
on the line so I just need to make sure i get these 2 strings at
least every 30 secs. Any ideas on how to handle this 30 second thing?
Thanks for the help and I'll take a look at a serial buffer.
Take care.
One serial buffer is www.protean-logic.com/tickit/rsb509B_HTML_Cutsheet.htm. Have a look at the description.
Thanks For sharinng this·with use that just might work for a project that i put on hold because of having·the same type of prolbem that Cheetah·is having in what (he/she) is trying to do..........
··Thanks for any·
Sam
