Propstick power
Hi all, for the initial experiments in the Propeller manual·can the Propstick be powered by the USB or is a seperate supply required. If I can use the USB as my supply what are the current limits. I am going to use a seperate regulator eventually but I just wanted to know if I could make a start just using the Prop and the USB cable with a couple of LEDs.
thanks
Jeff T.
thanks
Jeff T.
If that's too much of a pain, Try Bean's PropDongle!
Brian
uController.com - home of SpinStudio
Yeah the PropDongle is completely powered by the USB port.
Here is a link if you are interested http://www.hittconsulting.com/products/propdongle/
Bean.
My goal is to live forever...Or die trying.
Jeff T.
EDIT ok thanks Bean, I imagined the Propstick to be a similar setup, am I wrong?
EDIT 2 actually the dongle looks good I wish I had bought one
Post Edited (Unsoundcode) : 10/11/2007 6:47:41 PM GMT
