RFID Tag Ouput
Hi guys,
I have here the Basic Stamp homework Board with a RFID reader from Parallax Company. My plan is the following:
The reader should recognize the serial of the tag. I know, how the reader reads the tag. Now I want to make, that the reader sends this tag at the computer. But how? Is it possible to write down the tag (different tags) in a textfile? Does anybody have a solution?
Greetings, Tobias
Greetings, Tobias
2) You can buy an additional piece of hardware that can attach to the homework board and write information to a text file on a memory card or memory stick. The Parallax Datalogger (www.parallax.com/detail.asp?product_id=27937) is one such device.
1) I read something about the DEBUG statement. I think, it should work with the StampPlot. I think, that will be my last option to do it in this way.
2) This idea is very good. The only problem is, that I cannot connect this Datalogger on my board, because most of the needed space is used by the RFID reader.
I though about it and I came to the decison, that it should be possible to change the pins of the RFID reader.
Post Edited (skylight) : 10/11/2007 7:08:08 PM GMT
Hey,
I though about it and I came to the decison, that it should be possible to change the pins of the RFID reader. NOT A GOOD
This is not a good idea because i have try this and fried a RFID Card Reader Board doing it the best thing to do is take a solder bread board and cut it to the size to fit the 5 volt reg and the pins on the RFID Card Reader this works alot beter than trying to pull the pins off the RFID Card Reader Board trust me on this one
··Thanks for any·
Sam
