A couple of questions
I'm making a little project and have been pondering of these for a while.
1. Reading the Full Duplex object, just for clarification, it only requires 2 pins?
2. Is it possible to create an 8 bit R-2R Ladder DAC generate red, blue and green for VGA?
2) The VGA setup uses 3 x 2-bit R-2R Ladder DACs, one for each of red, blue, and green. There are also protective resistors in the outputs for H-sync and V-sync. Look at the schematic for the Propeller Protoboard.
doing more in color is possible but needs more than one COG (see: "Baggers"), Video generation for VGA is relatively simple.
The more I know, the more I know I don't know.· Is this what they call Wisdom?
Do you need something like attached jpg.
The resistors are for 1V P to P o/p, Not sure whether it should be
0.7V into 75 ohm ? DeSilva knows I should think!
In which case resistors should be approx. 4K0,2K0,1K0,500R
The 2 select lines effectively give you 4 palettes of 64 colours.
Yes Ken with 8 bit VGA memory probs, but can't have everything.
Best To All
Ian
:- A minor operation is one performed on somebody else!
ex:
The exact value ofthe resistors is not too important; you will hardly notice deviations around +/- 20% I NEVER use anything else but E3 values 1 - 2.2 - 4.7 (even for LEDs: either you need it bright: then take 220 , or if not so: take 470 ...)
But the DAC is also tricky! Note that you have a lot of inter-colour connections through the select nodes.
The video DAC is not a R-2R ladder, which needs high impedance buffering. It is rather a CURRENT ADDER, letting the sum of many current sources flow into 75 Ohms....
