Crydom D2W203F Solid State Relay
I'm trying to save some money on a project.· I only need two relays to fire 110v solenoid coils.
By specs it appears I can use the Crydom D2W203F Solid State Relay·directly to a BS2 output pin.
The BS2 can sink/source at least 20mA.· This relay only requires 3mA.
Am I missing something???· Or should this work!!!
Thank You,
Rob Jackson
oleancomputers.com
Thank You,
Rob Jackson
oleancomputers.com
Chris
Thanks for your response. Was wondering if I should use a diode, resistor or optical couple inline.
If any other ideas or thoughts come to mind let me know. I have a couple weeks to address this issue.
BTW - I'm building a control system for a Kart engine Dynometer.
RobJ
Thank You,
Rob Jackson
oleancomputers.com
