Add Stamp Lines
I know its in the forum somewhere please direct me to the post I can't find it in the search.
Thanks.
I need to add more input/output pins using the basic stamp 2p40.
Thanks.
The most common way to add more input/output facilities is to use shift registers. An 8 bit shift register will gain I/O facility at the rate of 1 Stamp pin port per 8 devices. In other words if you use an 8-bit shift register, the state (ON-OFF, 0-1) of 8 external digital devices can be fetched with one PBASIC instruction (SHIFTIN/SHIFTOUT). Obviously if you use a 16-bit shift register that same ratio is 1 x 16.
Two shift registers that are typically used with PBASIC Stamps are as follows:
Input Usage -
74xx165 8-bit parallal load shift register, parallel-in, serial-out
Output usage -
74xx595 8-bit shift register with internal storage register, parallel-out, serial-in/out, and tri-state outputs
Bruce Bates
There are other methods of I/O expansion that may be useful to consider as well.· Several of them are described in an application note at http://www.zbasic.net/appNotes/AN203.pdf.· Although the app note is oriented toward a different microcontroller the ideas can be equally well applied to any microcontroller.
Don Kinzer
ZBasic Microcontrollers
I have a project where I am trying to drive 39 7 Segment Displays using 1 BS2P40. I know it can be done my friend did it but won't tell me how.
I can drive three separate rows of 13 7 segment displays using three Stamps but I want to be able to drive all 39 displays with one stamp.
I use common anode 7 segment displays and the 7 cathodes are connected to a 7447 BCD to 7 Segment decoder to reduce the amount of pins used on the stamp from 7 pins to four pins.
All the cathodes are connected in parallel i.e. All Segment A's are connected together, B's, C's etc. I multiplex the displays by turning each segment on for only a certain amount of time. I don't have enough pins on the stamp to turn on all 39 anodes for each display using one stamp which is why I need to expand the amount of pins I have to be able to drive all the segments using one stamp. Please help me solve this problem.
www.maxim-ic.com
Tony
