Video Sync help
I need to create frame pulses at different speeds which stay in phase with the propeller composite out. For example output a 23.98hz pulse output which stays in phase with the 29.97fps video ouput. The video output is used to genlock other hardware. Can I use the VSCL frameclock to detrimine timing? Any ideas on how to do this? Thanks.
Bean.
My goal is to live forever...Or die trying.
www.hittconsulting.com
Graham
Beans question however seems unquestionable
Alright, so you need 4 signals during 5 frames or 2 during 5 fields or 1 each 2.5 fields.
So you should count the fields and output alternately at the start or in the middle of filed (or skip one).
I think there should be even time to output the line number to the HUB, so you can even handle that in SPIN with a jittter of around 20 us.
But the line retrace is a little bit tighter as it toggles the colour burst... I shall have a look tomorrow, if you have further questions.
But almost close. Was that a slide-rule calc?
Harley Shanko
