Supply Bypass Cap on Proto Board
Anybody know what type of bypass cap is being used on the proto board?· We had a serious noise problem on a project we're working on in the 60 MHz range at about 150mV p-p.· We added a 0.1uF ceramic in parallel to the 1uF that is already on the board and it killed the noise.
The more I know, the more I know I don't know.· Is this what they call Wisdom?
Graham
Graham
Try to increase the clock frequency without changing of application timing (most Propelers work upto 96 MHz (12 MHz x 8 or 6 MHz x 16) -> increased noise?
Reduce the application timing if possible -> reduced noise?
Leave out the video - if any -> reduced noise?
Increase Vdd to 3V6 -> reduced noise?
You say it's external noise, my sincere sympathies,
A good few years ago we were aligning floppy drives in the shadow
of Portsdown Hill ( Portsmouth UK ).
We learnt to ignore the pulses from the Navys 100kW+ radar that
were clearly visisble on the scope when looking for the cats eyes.
Hope you find a solution, short of a full Faraday cage!!
Best Regards
Ian
