5V Buck Regulator
My robot is going to have a main 12v source, not uncommon I'm sure. [noparse]:)[/noparse] I currently use 7805 regulators to achieve 5V, I've been researching 5V buck DC-DC regulators and was wondering if anyone else has had success driving SX's and propellers from these types of regulators. Is the power savings that much better than a linear Regulator? Can I build these right on the PCB that the Micro is on or does it have to be better Isolated.
What ICs are you using to convert from 12V to 5V?
Any experience and advice would be welcome.
Eric
Eric
You may want to check out Astrodyne’s product line. I have used their part #DU1P0-24S05 to power SX based devices from a 24V industrial supply that was already in the enclosure where the SX was being mounted. They have worked very well for me. The equivalent part number for you would be DU1P0-12S05 to convert 12V to 5V. These are 1 watt UNREGULATED converters. My application did not require regulated power, just something within the operating range for the SX and some attached peripheral chips. You might want to purchase a regulated converter or perhaps one with a higher power rating.
Having said that, if someone is going to design or locate a more inexpensive 12V to 5V DC converter I would like to participate or at least hear what you uncover. I do not claim that the Astrodyne parts are the best or the cheapest, only that they have worked well for me in a few applications where my main concern was dropping the voltage while reducing heat buildup.
- Sparks
I'm using LM2595 Switching Regulators. One Side is 3.3 Volts and The other is 5V Both from·a 12V Input.
Sorry about the crappy photo, I still have not managed to take good PCB Photos. I made this with 90% SMD parts.
Post Edited (SailerMan) : 10/25/2007 12:54:23 AM GMT
about taking pictures of PCB's try stand back about 3 ft' +/- then zoom in. doesn't always work but usually better than trying to do a close up shot.
Nice Project!
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Thanks for your positive comments. [noparse]:)[/noparse]
I know this unit runs perfectly from a 12 volt power supply, but I am not sure if it runs from a 12 volt battery.. If you only need this for a BenchTop unit this small unit already performs well.
I'll Post the schematic when I get home later.
OK it's later so I'm uploading a quick snap shot of the Basic Layout that I'm Using.
Post Edited (SailerMan) : 10/25/2007 11:25:24 PM GMT
Do you have any of these boards and parts for sale
Can you Please let me the cost of them you can PM
Thank you for your time in this matter
··Thanks for any·
Sam
I have not concidered selling these yet, I was trying it make it better and smaller. When that happens I can certainly let you know.
Eric
Steve
Thank You Eric
··Thanks for any·
Sam
It has the ability to monitor the input voltage of the battery and give visual feedback as well as a serial data stream. I know it's overkill but lots of fun.
I will build a basic twin power supply but I will need time to get this together as I wasn't planning on selling anything.. I will work up a price for the basic unit and let you both know. (Can you solder SMD ?)
Remember it is designed for 12V input. I have not tried a 9 volt input... But I will find out if it will function that way.
Here is a photo
Post Edited (SailerMan) : 11/29/2007 1:17:50 PM GMT
Based in my very limited experience... SMD's are not worthy of generating so much fear. They are actually easier than imagined... but as I said in the past... using a good "F L U X" was the key to my success.· In my case I used a highly active water soluable flux for very fast wetting action which resulted in a· quick two step soldering process (once across the lands on the board and then a quick reflow by passing the iron across the part and the copper lands).· This may not alsways work... but the flux I used acted so fast I had zero solder bridges.· Something ROSIN flux would never accomplish.
There's nothing like a new idea and a warm soldering iron.
Post Edited (pwillard) : 11/29/2007 8:20:58 PM GMT
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
I've been using my prototype above for about 1.5 years and it is still going strong.. I've been away from electronics for almost a year of that time so I have to catch back up. It's amazing how alien a project can seem after only a short time.
