Can I use a normal radio antenna on my GPS module?
Hello there,
Can I use a normal AM-FM radio antenna for better reception on my GPS module?·
Thanks for your comments.
Because of the very high frequencies involved, GPS also requires special coaxial cable and a very different antenna construction from that usually used for AM/FM.
To use my GPS module on a vehicle, I have to install it the complete module on the vehicle dashboard, I was thinking the temperature on that place is too high, I will look for an appropiate antenna to not expose my module.
If you can find a suitable low noise, broadband pre amp, how would you couple such a device to the inbuilt micro stripline antenna in the GPS module?
If you have more details perhaps you would care to post them.
Regards
Ron
