Help on OEM Design
Hello
I am interested in designing my own OEM Basic Stamp for various applications. Does anyone know the minimum component requirements for getting an interpreter to run correctly? Do I need any other components other than an oscillator, an interpreter, and an EEPROM?
Also, is it possible to "trick" the Basic Stamp Editor into thinking there is a stamp connected, when there is just an EEPROM connected? I had the thought that the interpreter could be on one board with a slot/socket for an EEPROM that would be separately programmed. Is this possible?
2) You can't "trick" the editor. The interpreter chip is what actually does the EEPROM programming. You can make up a special OEM Stamp Board with an EEPROM socket and program EEPROMs there and transfer them to the other boards. Just put a 4-pin header on your boards for Parallax's USB2SER adapter and use that for programming. There would be no programming components other than the header on the OEM boards.
- Rick
